Author Topic: Bally Rectifier Board J3 Connector Wiring Question  (Read 4625 times)
gajaman
  • Last login:July 19, 2011, 02:50:33 pm
  • The GajaCab is here......
    • The Gaja Project
« on: May 22, 2009, 09:12:31 am »
Can anyone tell me the correct wiring order and colours for a rectifier board J3 on a Bally Space Invaders?
I'm replacing the rectifier board and a previous owner has soldered the J3 wires direct to the board, I guess because of connector problems.
Here's a pic;
If anyone can tell me the pin number and correct wire colour I'd be very grateful - I want to be sure they are right!
« Last Edit: May 22, 2009, 04:52:24 pm by gajaman »
Neverending Project
    • Arcade Fixer
Re: Bally Rectifier Board J3 Connector Wiring Question
« Reply #1 on: May 26, 2009, 06:47:55 pm »
You can find tons of info here:
http://www.pinrepair.com/bally/index.htm
And specifically, your manual canbe found here:
http://www.ipdb.org/files/2252/Bally_1980_Space_Invaders_Manual.pdf
with the J3 pinouts and colors in the schematics toward the end of the PDF.
gajaman
    • The Gaja Project
« Reply #2 on: May 27, 2009, 04:38:12 pm »
Thanks for the reply Neverending Project. I have both of those documents but being a bit of a newbie still I didn't realise that the number reference on the connectors referred to the colour of the cable!
Now I can proceed with the new connector and check some other connectors that I've been worrying about.
Many thanks, really appreciate the help.
Hawkypro
  • Last login:October 13, 2009, 10:00:27 pm
« Reply #3 on: June 04, 2009, 08:36:03 pm »
Gajaman,
Replace and recrimp all of your molex connectors. I know it sounds extreme, but it will save you from an even bigger head ache down the line. I guarantee you that if the guy was this lazy with the rectifier board, then he was lazy with the rest of his repairs on this machine. People dont like to do the whole recrimp thing and pass it off. But, most pinball problems start at the connectors.
Hawkypro
As you can see Dr. Jones there is nothing you can posses; which i can not take away.
