Author Topic: 6 in 1 JAMMA board compatible with JAMMA+?  (Read 3332 times)
CodeWhite
  • Last login:September 10, 2009, 03:06:40 pm
« on: May 18, 2009, 05:14:33 pm »
Hey guys I have a question that maybe you can help me out with. I currently own Ikari Warriors 2, Ikari Warriors 3, and Heavy Barrel pcbs.  I have the opportunity to purchase a working Guerrilla War dedicated cabinet with LS-30 rotational joysticks. Since all these games require rotational joysticks to play, I would love to put them all in the Guerrilla War cab using a 6 in 1 JAMMA pcb. However, I heard that these games all use a JAMMA+ pin-out to accommodate for the extra inputs from the rotational joysticks. My question is: is the 6 in 1 compatible with JAMMA+, would I have to do some sort of mod to the board in order to get it to work, or am I just SOL?
If anybody can help me out I would appreciate it.
CodeWhite
FrizzleFried
    • Idaho Garagecade
Re: 6 in 1 JAMMA board compatible with JAMMA+?
« Reply #1 on: May 18, 2009, 08:14:29 pm »
If you're talking about the cheap Chinese junk that Yaton sells,  avoid it unless you're willing to do some serious hacking yourself.   They suck something fierce "as-is"...
tcleary
  • Last login:October 12, 2021, 12:30:19 am
« Reply #2 on: May 18, 2009, 11:51:31 pm »
my guess is you would have to wire the extra stuff seperately from each board like yourmameman did for using a 6 in 1 for multiple mortal kombats, you have to install some diodes
CodeWhite
« Reply #3 on: May 19, 2009, 09:26:13 am »
Thanks for the response tcleary. I figured as much. Nothing is ever simple in this hobby.  ;)
srarcade
  • Last login:June 18, 2018, 03:16:29 pm
« Reply #4 on: May 19, 2009, 09:29:08 am »
I think some of those multi devices don't even run -5V either. I know that was an issue with the midway pcbs.
« Reply #5 on: May 19, 2009, 07:02:23 pm »
Yeah, they don't have -5v.  You'll need to mod it.  I have a Smash TV and Total Carnage that I am looking to merge in 1 cabinet.  But luckily it's an easy mod.
~ D
MK3FAN
« Reply #6 on: May 20, 2009, 07:16:38 pm »
~ D
Here is how to do that...
[youtube]http://www.youtube.com/watch?v=536q_sAs9Z4[/youtube]
rusolinio
  • Last login:December 14, 2010, 08:21:22 pm
« Reply #7 on: May 25, 2009, 06:04:58 pm »
you can also install relays to cut the -5v to sockets that arent in use. (no need to supply a board with -5v if its not on!)
http://forum.arcadecontrols.com/index.php?topic=85941.msg907616#msg907616
