Author Topic: Ikari Sticks and Opti-PAC  (Read 883 times)
Beaps
  • Last login:July 09, 2020, 10:46:40 am
« on: May 10, 2009, 06:38:57 pm »
Hi All,
I got an SNK Ikari Stick and wanna wire it to my Opti-PAC.
The problem I have is I dont have a clue where to start. Do I run wires from microswitches to the Opti-PAC or from the large lomb on the bottom?
Ninten-doh
  • Last login:March 31, 2017, 10:37:18 am
  • I promise sweetie, this is my last cab purchase
Re: Ikari Sticks and Opti-PAC
« Reply #1 on: May 10, 2009, 08:28:14 pm »
Not sure if you can use an Opti-Pac for what you want to do, but Ultimarc has a dedicated interface for this for interfacing the 13 pin wiring harnesses:
http://www.ultimarc.com/rotary.html
The microswitches are connected as any regular joystick would be connected.  I think Randy T at GroovyGameGear has a rotary solution as well.
Good luck!   :cheers:
