Author Topic: Good 4-way stick  (Read 1216 times)
madk
  • Last login:March 28, 2017, 04:59:49 pm
  • I actually am a llama!!
    • Digital Something
Good 4-way stick
« on: July 02, 2003, 11:53:54 pm »
Hello all,
I'm about to venture forth into the world of 4-way joysticks. :)  I'm refurbing an old Red Alert cab about would like to add a 4-way stick along with my 2 8-ways.  I've never looked into 4-way sticks and need some advice.   I was looking at Happs and noticed there stick has a very short shaft.  I will be mounting this on 1/2" MDF and wanna make sure it sticks up enought.  Any suggestions..I know you have em!
Thanks in advance,
mad-k
Matt (mad-k)
Apollo
    • Eight Bells
Re:Good 4-way stick
« Reply #1 on: July 03, 2003, 12:22:12 am »
Firstly, have you used the "search" function? I know that's reall fatuous question but this topic has been pretty well covered.
Are you talking about the Happs PacMan/Galaga 4 way stick? If so then yes it is an awesome 4 way ( the best IMHO ) but if you buy it as is you won't be able to mount it in MDF as it is metal control panel only. You will need to either bmake a mounting plate or buy one. Oscar is your man for that.
paigeoliver
  • Awesome face!
Re:Good 4-way stick
« Reply #2 on: July 03, 2003, 02:31:05 am »
If you play ANY 4-way maze games then you will want a short handled stick, and the best short handled stick is the Ms. Galapac one. Just make a mounting plate. It is easy, I did it.
armad1ll0
  • Last login:March 28, 2012, 12:24:57 pm
  • The player and the builder!
    • Modeverything
Re:Good 4-way stick
« Reply #3 on: July 03, 2003, 04:34:56 am »
why not use a japanese stick and then leave it in 4-way mode...
paigeoliver
  • Awesome face!
Re:Good 4-way stick
« Reply #4 on: July 03, 2003, 05:06:17 am »
Japanese stick=long handle
Long handle=long throw
Long throw=eaten by ghosts
« Last Edit: July 03, 2003, 05:06:42 am by paigeoliver »
armad1ll0
    • Modeverything
Re:Good 4-way stick
« Reply #5 on: July 03, 2003, 06:27:57 am »
ya can always play on the keyboard if you want the smallest movements =P
TheManuel
  • Last login:April 09, 2025, 10:13:43 pm
  • On and off hobbyist
Re:Good 4-way stick
« Reply #6 on: July 03, 2003, 10:05:42 am »
I have that stick and very much recommend it.  It has very nimble response when playing Pacman and moving around like crazy through the maze.
I'll mount mine with a metal plate I took off an old hard drive that has the perfect hole in the middle of it.  It's only about 1/16" thick.  I'll lay lexan on top of the CP.
"The Manuel"
