Author Topic: [HELP] Puting two sides together?  (Read 3565 times)
Rusty Shackelford
  • Last login:April 20, 2013, 02:02:09 pm
« on: April 25, 2009, 05:38:48 pm »
Im having trouble coming up with a way of putting my two cab sides together.
The floor of the cab is recessed up slightly (to hide the castors) so I cant just use a square edge at the bottom.
Im thinking along the lines of clamping the two sides together and drilling the pilot holes through the two ,so when they are split they are in exactly the same place. Fitting the floor and top baton to one side should be easy enough, its putting on the othe side and lining it up thats making me scratch my head :banghead:
« Last Edit: April 25, 2009, 05:40:56 pm by Rusty Shackelford »
nuka1195
  • Last login:April 18, 2020, 08:47:25 pm
Re: [HELP] Puting two sides together?
« Reply #1 on: April 25, 2009, 06:12:25 pm »
cut a filler strip.
i personally use dados.
Rusty Shackelford
« Reply #2 on: April 26, 2009, 11:27:50 am »
Thanks for replying but im not sure what you mean.
Are you talking about routing a groove to place the parts in?
matman
  • Last login:January 18, 2021, 02:11:39 am
« Reply #3 on: April 26, 2009, 11:43:51 am »
couple ways you could achieve this.
1. dados (yes this is routing a slot for the bottom to slide into)
2. biscuit joiner - cuts slots and filled with biscuits
3. dowels from the inside- similar to biscuits..sometimes very hard to line up, but done so they are not exposed.
4. dowels from the outside - this will show from the outside.  line it up and drill holes from outside into the bottom piece, then stick dowels through and flush trim.
nuka1195
« Reply #4 on: April 26, 2009, 01:18:52 pm »
filler strip. i meant a spacer.
if this is holding the weight of the cab. i recommend dadoes. you could put a strip on top of the shelf to support the weight.
  • Last login:Today at 08:07:01 am
« Reply #5 on: April 27, 2009, 10:36:30 am »
Biscuits are the way to go for the joinery.  To line everything up just use a strip of wood as a spacer on the bottom of each side panel so you know exactly where the bottom panel will go.  If you are not using biscuits or dadoes I'd permanently install the spacer on each side so it can hold some of the additional weight.
ivwshane
    • My first mame cab! (WIP)
« Reply #6 on: April 28, 2009, 12:42:45 am »
I dadoed all my joints.
