Author Topic: Trackball Issue  (Read 1247 times)
olsteve
  • Last login:March 24, 2012, 10:33:35 pm
  • To play or not to play, that is a stupid question.
Trackball Issue
« on: April 14, 2009, 11:06:52 pm »
Hello-
I have a Happ USB/PS2 trackball and the left/right stoped working all of a sudden. It worked fine for over a year. Now the up/down works correctly but the left/right does nothing. I tried cleaning the optic board for the left/right but it didn't help. Do I need to get a replacement board or is there something simple I am overlooking?
Steve O.
Why is it when we talk to God we are praying, but when God talks to us we are put into the loony bin?
dmworking247
  • Last login:July 14, 2024, 01:30:59 pm
Re: Trackball Issue
« Reply #1 on: April 14, 2009, 11:12:11 pm »
It could be that your encoder wheel is out of alignment with the receiver, or it could be a faulty board.
Try manually moving the encoder wheel through the receiver to see if the cursor moves. Otherwise, try swapping the left/right board with the up/down board and see if the symptom follows the board (ie left/right would start working and up/down would stop)
olsteve
Re: Trackball Issue
« Reply #2 on: April 14, 2009, 11:32:21 pm »
Thanks for the reply. I did verify that the wheel is aligned with the sensor. I even tried to manually trip the sensor but I didn't get any response. The two boards are different sizes and I don't think I can swap them. I don't think it would help anyway because I can see that the wheel is going through the sensor. It must be a bad board. Does anyone know if/where I can get the board? The Happ website lists an upgrade for non USB trackballs that includes both boards and all of the wiring. I would like to just get the board if possible.
