Author Topic: Happ Competiton Shaft Dimensions?  (Read 2190 times)
Franco B
« on: March 30, 2009, 03:59:57 am »
Does anyone have the dimensions of the Happ competition shaft?
I'm after the following lengths + the diameters of the shaft.
A: Distance from the end of the shaft to the start of the e-clip groove
B: Distance from the end of the shaft to the start of the 2nd e-clip groove (or 2nd shaft diameter)
C: Distance from the end of the shaft to the bottom of the bat.
D: Ignore, I know its 146mm
I'm not sure if the 2nd 'line' on the shaft is a second e-clip groove or a change in diameter.
IIRC, the black section below the bat is a sleeve. Is that correct?
If you could also tell me the dimensions of the diameters of the shaft, including the e-clip groove(s) that would also be great.
I doubt if anyone has this data to hand but if someone with a digital vernier etc has a comp stick that they could measure I would appreciate it.  :cheers:
kowal
  • Last login:September 17, 2023, 02:02:16 am
  • Suzo 4ever
Re: Happ Competiton Shaft Dimensions?
« Reply #1 on: March 31, 2009, 11:58:41 am »
iL euro joystick
C-88mm
D-147mm
A-2mm
B-9mm
and E - 19mm (III groove)
competion
C-89mm
D-146mm
A-2mm
B-9mm
E-19,5mm
Franco B
« Reply #2 on: March 31, 2009, 12:54:07 pm »
Thank you kowal  :notworthy:  :cheers:
kowal
  • Suzo 4ever
« Reply #3 on: March 31, 2009, 03:22:24 pm »
groove is 1mm
shaft on end fi=10mm
groove fi=7mm
shaft cover fi=14,5mm iL, competion 14,7mm
battop fi=32mm on iL and fi=31,5 on competion
fi is diameter
You need this dimensions for custom balltop?
« Last Edit: March 31, 2009, 03:26:53 pm by kowal »
Franco B
« Reply #4 on: March 31, 2009, 03:39:15 pm »
Yeah, I'm making some Comp shafts with an M6x1 thread for the Seimitsu ball tops.
Grasshopper
« Reply #5 on: March 31, 2009, 04:46:04 pm »
For future reference, the dimensions of all the Happ joysticks can be found on the manufacturer's website:
www.industrias-lorenzo.com
