Author Topic: What's the smallest Power Supply Mini-ITX,  (Read 2681 times)
Chunce DeLeone
  • Last login:August 16, 2012, 02:58:11 pm
« on: March 29, 2009, 01:44:23 pm »
Whats the smallest power supply I can have for a mini-itx Laptop DVD, and onboard Audio and Vid. Looking to save space so even moding a ps would be worth it, prefer not to.
BobA
  • What Me Worry?
Re: What's the smallest Power Supply Mini-ITX,
« Reply #1 on: March 29, 2009, 07:49:18 pm »
Smallest PS is probably an external power brick with a plugin PS module that fits right into the power connector of the MB.  Lots of micro ITX use this type of setup.   The limiting factor however is how much power your need for your mini itx.   Usually depends on your CPU and video combination.  You can choose a low power MB and an efficient CPU and get in the 45 w range.
Chunce DeLeone
« Reply #2 on: April 01, 2009, 02:23:28 pm »
Update:  I am going with the PICOPSU-90,  should be delivered by next week, hope it works!!!!
Dermbrian
  • Last login:January 19, 2024, 05:05:16 pm
« Reply #3 on: April 01, 2009, 06:12:16 pm »
Care to share any details about what your project is?  Something small in size, low in power consumption?  Sounds interesting.
Brian
Chunce DeLeone
« Reply #4 on: April 02, 2009, 09:35:08 am »
Super small,  using the 15inch monitor as the boundary, and 4 inch deep,  I know about the heat issues that could happen, just want ot push the envelope.  Also yes small power consumption and one TB of storage.
Dermbrian
« Reply #5 on: April 02, 2009, 08:55:44 pm »
I'm strongly considering just buying an EEE Top and building an audio system/cabinet around it.  Low power consumption interests me, too, and I definitely want a touchscreen-based jukebox-style music system in the living room.
I wonder if  the EEE Top runs WinCab, SKJukebox, and/or Freebox (E-Touch), well, and wonder if the audio section is 'good enough' or if I could add a third party USB audio device to bring it up if it isn't.
http://www.newegg.com/Product/Product.aspx?Item=N82E16883220008
Brian
orion
« Reply #6 on: April 28, 2009, 03:06:01 pm »
Chunce DeLeone,
I am currently in the planning stages of my jukebox project and also am currently acquiring all my parts that I need. My 15 inch elo is on the way and I am considering a small T-amp and some 4x10 car speakers  (if they will fit). I was thinking of using one of these type power supply's as I am planning on making my jukebox only 4 inch deep as well. Also I don't want to hear a PSU fan running. I was planning on using a higher wattage one than you to power a mini ATX motherboard with an old Sempron I have laying around. Will these work for that? Also what transformer should I look for to run these PSU's I know it has to be 12V, but what amperage does it need to be.  Any input would be greatly appreciated.
Chunce DeLeone
« Reply #7 on: April 29, 2009, 10:19:21 am »
The PSU i used is :  FYI it gets really hot.
AC-DC 16V, 3.75A Switching Power Adapter (110/220V)
- Power adapter for all Micro Power Supplies
- INPUT:100~240Vac
- OUTPUT:16V 3.75A 60W Max.
- IEC 320 C6 (3P) connector
- Power Cord included
- 5mm/2.5mm barrel power jack
- RoHS compliant
orion
« Reply #8 on: April 30, 2009, 09:24:13 pm »
- INPUT:100~240Vac
- RoHS compliant
Good to know that those get hot.... scorching hot???? The reason I am asking is because I am trying to design mine without a fan in it (I have to meet strict W.A.F requirements on this one) Based on what your saying, I think I am going to give a 12v unit a try. Thanks for the info!  :cheers:
