Author Topic: Type of bolts for Happs Joysticks  (Read 1357 times)
16el
  • Last login:October 04, 2005, 03:06:26 pm
« on: June 30, 2003, 08:20:38 am »
Hello all,
Just another noob question.  What type of bolts do you guys use for the joysticks and where do you get them.
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
Re:Type of bolts for Happs Joysticks
« Reply #1 on: June 30, 2003, 10:07:11 am »
Traditionally people use 3/16" (is diameter the correct term for thread thickness?)  carriage bolts -- length depends on what surface you're mounting them through.
You can get them at most Aces, TrueValue, and smaller hardwar stores... although they won't be annodized black and may have a raised stamp (which you could grind down and polish if you so desired -- were that anal)
You can also get them from the real bob roberts or directly from happcontrols.com if you like paying a lot for a muffler.
You don't HAVE to use carriage bolts... I'm sure size 10 machine screws/nuts would work fine.  Some people go for a "flush" look and use wood screws from below -- but i'm not a big fan of that myself... *shrug*
Good luck!
Rampy
