Author Topic: Speaker Help?  (Read 1624 times)
wooowman93
  • Last login:September 04, 2014, 03:56:02 pm
Speaker Help?
« on: March 15, 2009, 02:43:10 pm »
ok i need help i want to connect this speaker with a
2nd generation ipod shuffle
I have headphones i can sacrifice
« Last Edit: March 15, 2009, 02:50:17 pm by wooowman93 »
BobA
  • What Me Worry?
Re: Speaker Help?
« Reply #1 on: March 15, 2009, 02:49:44 pm »
Unless your speaker is amplified you won't get much of a signal out of your shuttle earphone jack.
wooowman93
Re: Speaker Help?
« Reply #2 on: March 15, 2009, 02:50:45 pm »
i need it to play using the ipods power only
slapaham
  • Last login:January 31, 2012, 05:32:32 pm
Re: Speaker Help?
« Reply #3 on: March 15, 2009, 02:53:46 pm »
As BobA says - you'd need an amplifier to power that speaker - or you could use PC speakers with their own Mains power source (though, I'm sure you're aware of that already!) - the only speakers that the ipod could power itself, that I'm aware of, are those crappy headphone speakers that cost about £3.99 and sound AWFUL.
wooowman93
Re: Speaker Help?
« Reply #4 on: March 15, 2009, 02:55:38 pm »
ill have to see
my sister has a speaker powered by batteries
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
Re: Speaker Help?
« Reply #5 on: March 15, 2009, 03:05:53 pm »
It's not the power that's the issue - the signal needs to be amplified else the speaker will sound very very quiet. It's even worse than using USB-powered speakers on your PC if you want to run off your ipod. You will only get so much power through the headphone jack and will need more juice to power an amplifier. Even thos speaker docks that run on batteries for the ipod are mildly amplified.
Blanka
Re: Speaker Help?
« Reply #6 on: March 15, 2009, 03:28:47 pm »
What's the goal BTW? These speakers look really really crap! Go to a flee-market and get the cheapest PC speakers you can get (<1$) and it will sound better than this.
These speakers are for educational use only I guess. Or for use as blue-screen-of-dead-beeper in a PC-cabinet.
Turnarcades
    • Turnarcades
Re: Speaker Help?
« Reply #7 on: March 15, 2009, 03:30:29 pm »
Yeah, should have said it like that really.  :cheers: blanka
