Author Topic: Where does the coin microswitch go? SOLVED  (Read 3523 times)
rabidpuppy
  • Last login:July 21, 2015, 06:30:56 am
« on: March 08, 2009, 11:09:12 pm »
So I got this coin mech which is what I remember machines having as a kid, already set to take NZ/AUD 20 cent pieces ("hey gimmie some twennies!" - me 1982).   But I don't understand the where to put the microswitch (pic 2, pic 3-4 shows left & right sides).  I have no idea and it did not come with any instructions, but it looks like a standard device.
Another problem (Pic 1) shows a coin not going through properly, which makes me think I have moved something by mistake and it is no longer set to accept 20c pieces.   Is there a For Dummies on how to work these?
Cheers!  Pew pew pew (me playing Time Pilot 27 years ago)
« Last Edit: March 14, 2009, 08:24:42 pm by rabidpuppy »
daywane
  • GRRRR!
Re: Where does the coin microswitch go?
« Reply #1 on: March 09, 2009, 11:39:35 pm »
at the bottum.
as coin travels in the track it will hit a switch "long L shaped wire"
just before coin hits bucket
it is a special type switch. not like the buttons on CP
rabidpuppy
« Reply #2 on: March 11, 2009, 06:53:48 am »
at the bottum.
Okay I figured out where to attach it.  Now what do I do with that wire?  Bend it?
I also still can't make a coin go through without it being caught and having to be rejected (see very first pic in first post).
« Reply #3 on: March 11, 2009, 07:02:39 am »
I have never seen a coin mech like this one, but just guessing, I would say the wire needs to bend up into the slot so the coin will push the wire down as it falls through. (See modified image below).
I have no idea why the coin is hanging. Looks like a catch at the bottom of the coin has it. have you tried tying it back?
rabidpuppy
« Reply #4 on: March 14, 2009, 08:22:26 pm »
Thanks all sorted now.   For future reference of anyone else who may have this mech (the CM01 Mechanical "Classic" Coin Mech as sold by OzStick):
This shows the coin rolling correctly, the piece that has "CA CALLE" embossed on it needs to be very very slightly below the top level of the coin:
You can adjust this level by unscrewing here and dropping slightly:
Here is the bent microswitch wire as advised by DaOld Man (thank you).  Note it is much easier to bend it BEFORE attaching the microswitch:
Simulated action shot!   ;) Coin drops directly onto bent wire, pushing it back enough to trigger the microswitch:
Cheers!   (Please ignore that very distracting "tic tac orange bigbox" in the background of that last picture)
