Author Topic: Looking for Beta testers 1.62g (Finished)  (Read 66148 times)
loadman
    • MaLa
Re: Looking for Beta testers 1.62e
« Reply #80 on: April 13, 2009, 11:02:50 pm »
Here is the latest beta.
It fixes bugs this like:
- correct orientation
- Playing videos when game is running
http://www.malafe.net/files/download/MaLa162e.zip
Notes:
* Recommended: Use in a separate mala directory (so you don't mess up you current gaming setup). Copy files across from your real setup.
* This version may freeze at any point when loading a video. This is a restriction of the evaluation version of the video engine.. I hope  ;)  This is more so than before as there is no message on screen about evalutaion as I turned that off.
Thanks in advance for you feedback  :cheers:
« Last Edit: April 19, 2009, 08:10:38 pm by loadman »
« Reply #81 on: April 13, 2009, 11:13:56 pm »
Hi Loadman
I have to second the others sentiments about the work you've done on Mala, it's a very slick application! :notworthy:
This particular issue is very strange.
I'm getting the more verbose log now, but basically the same error.
Here's the log (whole thing, I cleared it and then ran the prog.)
2009/04/13  22:05:11.21   Info: ##########################################################################
2009/04/13  22:05:11.22   Info: ##########################################################################
2009/04/13  22:05:11.23   Info: **** LOGGING AT VERBOSE LEVEL *****
2009/04/13  22:05:12.82   Info: Starting MaLa 1.6.2.10
2009/04/13  22:05:12.85   Info: LoggingLevel =  2
2009/04/13  22:05:12.89   Info: Check plugin directory: o:\mame\Mala\plugins
2009/04/13  22:05:12.91   Info: Collecting event plugins (*.mplugin) in o:\mame\Mala\plugins\
2009/04/13  22:05:12.95   Info: Check backup directory: o:\mame\Mala\backups
2009/04/13  22:05:12.97   Info: Check to see if hook dll is required
2009/04/13  22:05:12.98   Info: Win98/ME Hook dll not loaded because OS is: WinVista
2009/04/13  22:05:13.05   Info: Loading config params from ini file
2009/04/13  22:05:13.24   Info: Setting params from ini file
2009/04/13  22:05:13.25   Info: Creating and loading mame cl conditions: o:\mame\Mala\mame.clc
2009/04/13  22:05:13.31   Info: Creating and loading mame info pages: o:\mame\Mala\mame.mli
2009/04/13  22:05:13.32   Info: Creating and loading other emu info pages: o:\mame\Mala\otheremu.mli
2009/04/13  22:05:13.34   Info: Creating and loading filter sets: o:\mame\Mala\mala.mlf
2009/04/13  22:05:13.35   Info: Creating and loading non mame emulators: o:\mame\Mala\mala.mle
2009/04/13  22:05:13.36   Debug **: Emulator: Loading List
2009/04/13  22:05:13.38   Info: Creating and loading layout ...
2009/04/13  22:05:13.48   Info: Collecting layout files (*.mll) in o:\mame\Mala\Layouts\No18Arqadium\
2009/04/13  22:05:13.52   Info: Creating and loading mala tree
2009/04/13  22:05:13.55   Info: Collecting game list files (mlg) in o:\mame\Mala\
2009/04/13  22:05:13.57   Info: Creating and loading bios
2009/04/13  22:05:14.05   Info: Creating audio object
2009/04/13  22:05:14.34   Info: Creating and loading mala lcd screens
2009/04/13  22:05:14.37   Info: Creating and loading mame lcd screens
2009/04/13  22:05:14.39   Info: Creating and loading jukebox lcd screens
2009/04/13  22:05:14.41   Info: Creating and loading led config and attroct mode list
2009/04/13  22:05:14.42   Info: Collecting attract mode files (*.mlc) in o:\mame\Mala\
2009/04/13  22:05:14.45   Info: Changing Layout
2009/04/13  22:05:14.46   Info: Loading layout: o:\mame\Mala\Layouts\No18Arqadium\No18Arqadium.mll
2009/04/13  22:05:15.34   Info: Displaying Game List:
2009/04/13  22:05:15.35   Debug **: Cancel any Display & Video Delay due to list change
2009/04/13  22:05:15.36   Info: Scroll Delay:
2009/04/13  22:05:15.56   Debug **: Display Delay Enabled
2009/04/13  22:05:15.57   Info: Show Main Form
2009/04/13  22:05:15.65   Error: Object Class: TfrmMain, Object Function: FormShow, Exception Class: EOutOfResources, Exception Message: Not enough storage is available to process this command.
2009/04/13  22:05:15.70   Debug **: Display Delay
2009/04/13  22:05:15.71   Debug **: GetDefinablefilename function
2009/04/13  22:05:15.73   Debug **: Mame Def 1 path: o:\mame\Mame129\cabinets naming # 0 selected # 0 filename: o:\mame\Mame129\cabinets\alexkidd
2009/04/13  22:05:15.84   Debug **: Definable 1- Loading snap of master: o:\mame\Mame129\cabinets\alexkidd
2009/04/13  22:05:15.85   Debug **: GetDefinablefilename function
2009/04/13  22:05:15.93   Debug **: Definable 1- Loading default: o:\mame\Mame129\cabinets\
2009/04/13  22:05:15.95   Debug **: GetDefinablefilename function
2009/04/13  22:05:16.00   Debug **: Mame Def 2 path:  naming # 0 selected # 0 filename: \alexkidd
2009/04/13  22:05:16.01   Debug **: Hiding Definable 2
2009/04/13  22:05:16.02   Debug **: GetDefinablefilename function
2009/04/13  22:05:16.04   Debug **: Mame Def 3 path:  naming # 0 selected # 0 filename: \alexkidd
2009/04/13  22:05:16.05   Debug **: Hiding Definable 3
2009/04/13  22:05:16.06   Debug **: GetDefinablefilename function
2009/04/13  22:05:16.07   Debug **: Mame Def 4 path:  naming # 0 selected # 0 filename: \alexkidd
2009/04/13  22:05:16.09   Debug **: Hiding Definable 4
2009/04/13  22:05:16.10   Debug **: Saving Tracking Info
2009/04/13  22:05:18.61   Info: Showing taskbar
2009/04/13  22:05:18.65   Info: Screensaver: ScreenSaver Form Destroyed
Notice the Not enough storage error right after trying to show the main form.
The error "could" be related to my layout, but again, if I shut down all other programs, I can usually get it to run.
I'm not using any videos at this point, just static JPGs and PNG's in my layout.
loadman
    • MaLa
« Reply #82 on: April 13, 2009, 11:28:34 pm »
Keep in mind the source code for mala was passed to me. I did not write 95% of it. The great Swindus did.  I am keeping the fire burining and adding little bits and pieces
Are you using a starting Video?
Can you backup you mala.ini file then remove it so you can start again.  EG create a new mala.ini.
Just add bits at a time add see at what point it is having trouble. A guess is the layout graphics. If you change to deafult is it OK?
Very Odd.
You could later  try it on another PC as it could be OS related? Try defaults first then later copy the mala folder over from the PC your are having issues with
« Last Edit: April 13, 2009, 11:32:25 pm by loadman »
« Reply #83 on: April 14, 2009, 12:52:04 am »
Will do. I'm guessing it's something about my layout as well.
No startup video, at least not yet.
I'll try reducing the mala.ini and seeing what happens.
loadman
    • MaLa
« Reply #84 on: April 14, 2009, 01:06:00 am »
Or just move/copy it and let mala build  a new one and start again to see what happens
bsweet0us
  • Last login:December 18, 2020, 09:59:46 am
« Reply #85 on: April 14, 2009, 07:28:34 am »
url=http://www.malafe.net/files/download/MaLa162e.zip
Notes:
Download link not working.  It's got an extra URL=http// in front of it, but even when I delete that it takes me to a search page.
ETA: Appears to be a typo...remove "url=http://" and add a colon after the second http.
or click this link: www.malafe.net/files/download/MaLa162e.zip   ;D
« Last Edit: April 19, 2009, 08:10:23 pm by loadman »
Ummon
  • Trade Count: (+13)
« Reply #86 on: April 14, 2009, 04:24:11 pm »
Just back from the doctor. Healing up well.  I got the injury due to failed 'beach start' but I got dragged over a very sharp shell fish (Razor Fish).
Start from the beach, huh? I've only skied once, almost twenty years ago, but we started in the water. Anyways, don't fret Loadman. Yer doin good.
Yo. Chocolate.
Stephen Hawking
loadman
    • MaLa
« Reply #87 on: April 14, 2009, 08:11:04 pm »
Opps Link fixed, Thanks
Any Testers?
« Last Edit: April 19, 2009, 08:10:53 pm by loadman »
bsweet0us
« Reply #88 on: April 14, 2009, 10:55:17 pm »
I didn't notice any substantial difference between this latest release and the previous one.  I can report that I had to remove two videos from from Genesis gamelist prior to using the new video engine and I re-added them with this latest release and it worked flawlessly.
I didn't extensively test the new engine, but I am exhibitin no problems that were present for me with the previous engine.
My hat goes off to you loadman for all the hard work and improvements you have put into MALA since taking over for Swindus (who deserves a ton of credit as well).  Keep up the good work and I truly believe you are incrementally making the MALA frontend better and better.
Thanks for all you do. This one's for you... :cheers:
dungbeetle46
  • Last login:June 25, 2016, 07:27:47 pm
« Reply #89 on: April 14, 2009, 10:59:55 pm »
Hi Loadman, have added some vids and done some testing, seems fine to me, no probs so far. and the slight delay is neglible
I dont know if its an easy fix but I am still having a problem generating a gamelist for mame with the newer versions, I need to gen the list with 1.5, it gets just past the using collection options then the window pops up Mala has encountered a problem and needs to close.
cheers Dung
loadman
    • MaLa
« Reply #90 on: April 14, 2009, 11:06:58 pm »
Thanks  ;)
I will check this. When you say 'newer versions' from what version so I can download it to check. I use older version so I may well not have seen this.  I just tried it and works with 89 & 107
« Last Edit: April 14, 2009, 11:10:06 pm by loadman »
TheShanMan
  • Last login:October 16, 2023, 03:35:12 pm
    • My Arcade (updated 1/30/13)
« Reply #91 on: April 14, 2009, 11:49:47 pm »
Loadman, I'm pleased to state that the latest version is MUCH better with regard to the delay before video startup! :applaud:
The new video engine is also handling the faulty Super Mario Bros. video flawlessly. In fact, I recall trying that video in WMP and it showed sync'ing problems. And of course MaLa would hang with it. But now it not only doesn't hang, but somehow the audio and video are more or less in sync!
Oh, and also it's nice that the "use mouse" option stays enabled after resuming from stand by. While it's unfortunate that you had to solve it with a hacky solution like "wait 3 seconds and then re-enable it", I can't say I'm displeased in practice. It takes a few seconds for things to settle down and the screen to warm up anyway.
« Last Edit: April 14, 2009, 11:57:24 pm by TheShanMan »
loadman
    • MaLa
« Reply #92 on: April 15, 2009, 12:01:40 am »
I forgot to re-enable the faulty Super Mario Bros. video to see how well MaLa handles it now. I'll give that a try and report back.
Cool
Still not quite ready for release as it has a problem if you quit before the video loads it will crash, not ideal. ie if you go to the next item in the list (with a video) and quickly right click before the video loads then exit.
I can recreate this problem in a mini test ap, weird thing is it only happens on delphi 5 not 2007. Yet more incentive for me to move development to delphi 2007. Doing so is a bit of a headache as most of the 3rd party components I only have delphi 5 code. The other downside is it will take some time, anyway I am doing this regardless slowly in the background.
« Last Edit: April 15, 2009, 12:19:31 am by loadman »
TheShanMan
« Reply #93 on: April 15, 2009, 12:31:16 am »
Loadman, note that I edited my prior post. Your quote has the original content so in case you didn't see my edit, have another look at my post.
loadman
    • MaLa
« Reply #94 on: April 15, 2009, 12:40:18 am »
Sweet, I am getting there. Thanks  :cheers:
If you intend to leave it running on your cab then keep in mind there are still some scenarios I have not caught yet where it may hang or crash.
Note to all:  If you can recreate a crash/freeze please send the log (in verbose mode to me)  ;D
Send Bugs to :    bugs@malafe.net
Thanks all for you continued support "Help me help you"   :laugh2:
« Last Edit: April 15, 2009, 12:53:11 am by loadman »
dungbeetle46
« Reply #95 on: April 15, 2009, 04:49:53 am »
I meant newer version of mala
1.5 generates my mame list but 1.6 crashes, this is with around 5000 sets.
this is the log
2009/04/15  18:26:03.92   Error: Object Class: TPopupList, Object Function: SaveBiosList, Exception Class: EAccessViolation, Exception Message: Access violation at address 7C912C16 in module 'ntdll.dll'. Write of address 004041C9
« Last Edit: April 15, 2009, 05:03:31 am by dungbeetle46 »
TheShanMan
« Reply #96 on: April 15, 2009, 12:09:15 pm »
Definitely plan to keep it running provided it's somewhat stable. I know it's beta quality so I'm not expecting perfection, but I'd rather give it plenty of usage so I can give you feedback as necessary.
loadman
    • MaLa
« Reply #97 on: April 16, 2009, 07:44:12 pm »
Hi,
An update.
Testing is going very well.   :)
I discovered a bug in the Video Engine that I reported to datastead and they fixed very it quickly. Videos are loading faster and more stable.  ;D
I also managed to get all the mala tools (layout, editor etc) compiling on Delhi 2007 which makes life easier for me. One day I will get mala on it too.
I am feeling positive about MaLa development now. I hope to soon get back to the fun job on implementing enhancements.
I may release another beta tonight.
« Last Edit: April 16, 2009, 07:51:27 pm by loadman »
zophar707
  • Last login:June 10, 2010, 04:03:06 pm
« Reply #98 on: April 17, 2009, 04:26:34 am »
Only thing i have encountered so far on this new beta is, it takes a lot longer to exit Mala.  It isnt a major gripe.
Keep up the great work  :applaud:
loadman
    • MaLa
« Reply #99 on: April 17, 2009, 06:27:31 am »
Thanks for the feedback  ;)
I think I have fixed that too. I put the delay to stop mala crashing out at one point. It takes just under 2 secs to exit for me now.
zophar707
« Reply #100 on: April 19, 2009, 02:37:54 pm »
I have one more query.  My command wrapper for pj64 doesnt seem to work now. it comes up with this error
The application failed to initialize properly (0x0000135). click on ok to terminate the application.
It works without the wrapper but when i press escape to exit game it just goes to the pj64 emulator.
Dioskilos
  • Last login:February 09, 2012, 10:10:11 am
« Reply #101 on: April 19, 2009, 04:53:35 pm »
When I go to:
Option>Mame Config>Basics>Config>Vector
I change the "Intensity" from it's default of 1.50 but it never seems to save this setting.
Am I doing something wrong?
TheShanMan
« Reply #102 on: April 19, 2009, 05:06:18 pm »
I think that doesn't work in MAME. I tried setting that one time a couple of months ago in MameUI and it never seemed to take.
loadman
    • MaLa
« Reply #103 on: April 19, 2009, 06:03:46 pm »
 ??? Are you sure this is related to this beta. What happens when you revert mala.exe back to 1.05?
loadman
    • MaLa
Re: Looking for Beta testers 1.62f
« Reply #104 on: April 19, 2009, 08:07:36 pm »
OK.  I Paid (at a reduced price) for the non eval version for the Video Engine (TVideoGrabber)  :P
So the videos should not randomly pause anymore.   8)
Download latest beta here:
http://www.malafe.net/files/download/MaLa162f.zip
Send Bugs reports to :    bugs@malafe.net
Thanks For reporting everyone  :applaud:
« Last Edit: April 29, 2009, 08:30:03 pm by loadman »
TheShanMan
« Reply #105 on: April 19, 2009, 08:48:58 pm »
Very cool! 8) I'm sure you don't want people to feel pressured to donate, but may I ask how much you ended up having to pay for it? I'm sure there are plenty of us who would be happy to donate to help cover the cost!
loadman
    • MaLa
« Reply #106 on: April 19, 2009, 09:55:54 pm »
MaLa is Free  ;D  ...but any token donation is appreciated.  ;)
I do appreciate any form of support especially helping other users in this Forum and updating the wiki  :applaud:
« Last Edit: April 20, 2009, 12:50:17 am by loadman »
zophar707
« Reply #107 on: April 20, 2009, 02:41:55 am »
My bad it appears im missing the Microsoft .NET framework.
Its all working again,  now for the next beta   :cheers:
wooowman93
  • Last login:September 04, 2014, 03:56:02 pm
« Reply #108 on: April 21, 2009, 04:06:23 pm »
It seems 1.62f crashes a lot when using a tree
SGT
  • Last login:April 17, 2023, 08:29:42 pm
« Reply #109 on: April 21, 2009, 07:52:20 pm »
Just a wild-assed guess, but I'm thinking loadman needs more details on exactly what you're doing when it crashes, and a view of the log.  Also thinking he'll want to know if it crashes with videos off and if it doesn't which videos it crashes on.
Of course I've been wrong many times before.
loadman
    • MaLa
« Reply #110 on: April 21, 2009, 08:29:05 pm »
yes some details so I could fix would be nice  ;)
dungbeetle46
« Reply #111 on: April 21, 2009, 08:39:50 pm »
I use a tree and I have been trying to make it crash but it wont, my tree used to crash when returning back to the tree list from an emulator, in the log it said something about loading custom picture just before it crashed so I changed my tree background pic from png to jpg and that stopped it from crashing.
loadman
    • MaLa
« Reply #112 on: April 21, 2009, 08:51:34 pm »
Can you email the background pic that was  the problem   bugs@malafe.net
dungbeetle46
« Reply #113 on: April 21, 2009, 09:20:11 pm »
sent
wooowman93
« Reply #114 on: April 21, 2009, 10:29:26 pm »
Ya i just changed all the backgrounds to jpg(they were png) and it stopped crashing
loadman
    • MaLa
« Reply #115 on: April 21, 2009, 10:48:11 pm »
Interesting, can you send me one of your png's to bugs@malafe.net
dungbeetle46 sent me one and it is causing problems so if I have a few examples of problem images I can validate a mala fix for it.
« Reply #116 on: April 21, 2009, 10:59:21 pm »
I'll second that about the PNGs. Originally, with 1.5, I was using a (admitted very large) png as a background and crashed quite often.
Switched to jpg and the crashing quit (I got the "out of resources" error).
But haven't tried PNG's with 1.62 yet.
The PNG's I used were created in FireWorks, so they had lots of extra "baggage" though.
loadman
    • MaLa
« Reply #117 on: April 22, 2009, 01:06:25 am »
Thanks for that ;-)
« Reply #118 on: April 22, 2009, 08:07:00 am »
Hi Loadman
Sorrry about that, i guess my last post could have used a tad more detail  :-[
I've sent an email to the addr you supplied with the questionable png file. It's 13mg, so if it doesn't make it, just email me back and I'll get it to you some other way.
Ummon
« Reply #119 on: April 22, 2009, 02:15:47 pm »
When I go to:
MameUI no longer has 'intensity' in its features, so I'm guessing neither does base Mame. What I've done instead is set advanced>full screen contrast to 1.3, and display>contrast correction to 2.0 .
Yo. Chocolate.
Stephen Hawking
