Author Topic: My custom made MaLa icons including hires and 16M colors + alpha (XP)...  (Read 4589 times)
EmuMannen
  • Last login:January 28, 2009, 03:13:11 pm
Hi everyone. It's almost 10 years since I built my MAME cabinet with much help from the BYOAC community. It has worked flawlessly under DOS with an AdvanceMAME front-end. The hardware is however in great need of an upgrade but my new hardware doesn't play well with DOS. I would love to power my cabinet with Linux but I guess I have to settle with a nLited XP until SDLMAME is up to par with MAME under Windows...
It was while looking for a new front-end I stumbled upon MaLA. It looks really promising and it is what I am planning to use for my upgrade. One of the first things I noted was the nice icon of MaLa.exe and I thought to my self - “it's a shame that the rest of the MaLa executables doesn't have as nice icons”. I soon realized that I needed to put together a new layout since none of the existing is perfect for my cabinet. So I decided to crank out some new icons while I had Inkscape running...
I don't know about you but I hate when an application doesn't have high color icons with transparency in XP. I know it's not important but hey, these ones are for free! I couldn't find an original of the MaLa.icon so I just draw a copy by hand in Inkscape. I then used that one and overlaid some additional nice graphics from the Oxygen project on top of it to represent the additional executables. Feel free to use these icons or it's original anyway you want. And that includes the MaLa development team. :)
Back to work with my new layout...
Update: I took a look at these icons and realized that they needed some additional tweaking. Minor details but anyway. I have replaced the zip-file and screen shots with new and, in my opinion, better versions.
« Last Edit: January 15, 2009, 03:27:14 pm by EmuMannen »
EmuMannen
Re: My custom made MaLa icons including hires and 16M colors + alpha (XP)...
« Reply #1 on: January 13, 2009, 03:58:14 pm »
Maybe I should have attached a preview of the icons too...  ::)
« Last Edit: January 15, 2009, 03:28:43 pm by EmuMannen »
loadman
  • Moderator
    • MaLa
« Reply #2 on: January 15, 2009, 07:30:27 am »
Thanks  :cheers:
I like most of them.
MaLa Attract and GameList don't seem quite right to me.
Is it just me  :dunno
Thanks anyway
I will use those  ;D
You might want to check out my other post here:
http://forum.arcadecontrols.com/index.php?topic=80457.0
In Particular this one:
http://forum.arcadecontrols.com/index.php?topic=80457.msg861718#msg861718
« Last Edit: January 15, 2009, 07:34:37 am by loadman »
EmuMannen
« Reply #3 on: January 15, 2009, 04:57:32 pm »
Ok, I hear what you say... Back to the drawing board... Postpone my layout another day...   ;D
Attached is a new attempt with overlays based on Everaldos Crystal Icons, is it for the better?  8)
EmuMannen
« Reply #4 on: January 15, 2009, 05:30:59 pm »
In Particular this one...
I made a new SVG drawing based on the original PNG by Neilyboy (se attached file and preview). Would you like me to replace the backdrop in my icons with that one instead and re-render the icons?
Update: Tweaked colors and gradients a bit to better reflect the original...
« Last Edit: January 18, 2009, 07:40:44 pm by loadman »
loadman
  • Moderator
    • MaLa
« Reply #5 on: January 18, 2009, 07:40:57 pm »
That is great.  In my opinion anyway.   :P
Yes if you have time give them the 'Neilyboy' treatment.
Either way they are all going to used on the next version  :cheers:
EmuMannen
« Reply #6 on: January 19, 2009, 04:52:06 pm »
I will fix ASAP...
loadman
  • Moderator
    • MaLa
« Reply #7 on: February 06, 2009, 08:48:50 pm »
I will fix ASAP...
Hello
Have you got time to finish these by turning them into 'nellyboy' icons or should I apply the previous version?
