Author Topic: mouse doesn't scroll game list after standby  (Read 4027 times)
TheShanMan
    • My Arcade (updated 1/30/13)
« on: January 02, 2009, 02:17:53 pm »
After I put the computer into standby mode and then it resumes, the mouse no longer works for selecting games, but it does work in a game. I have tried hand editing mala.ini to turn it on, but that setting still gets lost. This is especially annoying to me because I have swappable panels so when I have my trackball panel installed the mouse is my only option for selecting games. This forces me to either swap to a different panel, or pull out the keyboard/mouse and turn the option back on.
loadman
  • Moderator
  • Last login:Yesterday at 07:18:10 pm
    • MaLa
Re: mouse doesn't scroll game list after standby
« Reply #1 on: January 02, 2009, 05:15:32 pm »
Bugger...
Has it always been this way since I added the standby option or is this a problem that has just started on your rig?
TheShanMan
« Reply #2 on: January 02, 2009, 11:18:31 pm »
I'd imagine ever since adding standby... for a while I wasn't using my trackball panel, and recently I've started using it fairly regularly. So as far as I know it's always been a problem since you added that feature.
loadman
  • Moderator
    • MaLa
« Reply #3 on: January 03, 2009, 12:27:23 am »
That is the answer I wanted to hear.   ;D
Probably something easy to fix then
loadman
  • Moderator
    • MaLa
« Reply #4 on: January 03, 2009, 05:42:03 pm »
This has been fixed.
It was a less trivial to fix than I thought it would be .
MaLa crashes if mouse is enabled when you resume from standby.
So to make it work I added a delay of 3 seconds (while still processing windows messages) before the mouse is re-enabled.
TheShanMan
« Reply #5 on: January 03, 2009, 05:49:29 pm »
Cool that it's fixed, but sorry you had to solve that crash in a less-than-ideal way. It probably bugs you as much as it does me to code those kinds of solutions! Look forward to the next release!
loadman
  • Moderator
    • MaLa
« Reply #6 on: January 03, 2009, 06:29:55 pm »
Yeah it does bug me, But to fix that I would have to solve a bigger mouse support issue. It is not worth it right now.
Next release will be when I get around to finishing the definables on other emu's.  I have not looked at that code for a while but it was a a point where I had to make some key decisions about backward compatibility with layout files.
TheShanMan
« Reply #7 on: January 04, 2009, 12:21:20 am »
Well, thanks a lot loadman! You're doing some great work that I (and I'm sure many) really appreciate! I can't tell you how much I love the standby support.
