October 15, 2025, 09:01:45 pm
You need to use the UltraMap program and change the IDs of each stick.
The problem might be a Windows issue.You could try setting to ID 2, then in Control panel, System, Device Manager, open the USB Controller entry and right click and Uninstall the composite devices there. Then unplug and reconnect.Andy
Just out of curiosity what entries did you delete? (from the registry)
Please do, just in case I need it.Thanks.
