Author Topic: For SALE ( back on sale! ) Lot of 16 - 25" in-wall monitors [Seattle WA USA]  (Read 11046 times)
BASS!
  • Just have fun.
I stumbled upon a huge deal at work. I will soon have 16 video-wall monitors I need to get rid of. My source had a large display that they are now changing out. The old multiplexer is broken, and now just the screens are left. Due to weird reasons a bunch flaked on buying. Got 9 left:-)
Price is $25 each, just doing this to put some monitors in your guys cabs for cheap. The money is going to pay back myself for the renting of the truck, and paying my buddy for helping me lift em.
specs!
Product Features
Features
    * FST Black Matrix 28" CRT
    * Automatic Priority: video 1 - RGB - video 2 (only NBP)
    * Colour System PAL/NTSC
    * CTI & Comb filter (only NBP)
    * Colour temperature: 6.500°K / 3.299°K (selector)
    * SCART/Peritel: RGB + video 2 (only NBP)
    * Random Delay on switching-on (adjustable) 5:15 sec.
    * External regulations for geometry and picture adjustment
    * Mains voltage: 110-120V Ac / 220-240V Ac
Picture Tube
    * CRT: 28" CRT (71 cm diagonal), World-wide
    * Dot pitch: 0.8 mm
Electronics
    * Colour system (SMV300 NBP only): PAL & NTSC automatic selection
    * CTI & Comb Filter (SMV 300 NBP only): standard
    * Signal inputs: Composite Video, RGB +Sync
    * RGB bandwidth: 7 MHz ±3dB
    * Horizontal scan frequency: 15.625 Hz ±600Hz (PAL); 15750 Hz ±600Hz (NTSC) automatic selection
    * Vertical scan frequency: 50-60 Hz autolock, with automatic size control
    * Cut off: automatic
    * Colour temperature: 6500°K (normal) and 3200°K (internal selection switch)
    * Colour temp. adjust.: 6500°K internal adjustment for both black level and white level
Input/Output
    * Analog RGB input: (SMV 300 RGB): via Canon DB9 connector.
    * Analog RGB input (SMV 300N - 300 DELTA): via Canon DB9-sub and SCART socket.
    * TTL RGB input (SMV 300N - 300 DELTA only): via Canon D9-sub
    * Video input 1 (SMV 300N - 300 DELTA only): via BNC connector
    * Video input 2 (SMV 300N - 300 DELTA only): via SCART socket
    * Video output (SMV 300N - 300 DELTA only): via BNC connector (passive loop-through) just for Video input 1
Controls
    * External controls (SMV 300 RGB): brightness; contrast; colour saturation and Hue; H and V amplitude, H and V shift.
    * External controls(SMV 300N - 300 DELTA):brightness; contrast; H and V amplitude, H and V shift; Keystone, Pincushion and vertical linearity.
    * Main switch
    * External switch (SMV 300N - 300 DELTA): 75? on/off (only for Video 1)
Electrical Data and Operating Conditions
    * Warm up time: 30 minutes
    * Degaussing: Automatic when switched on
    * Switch on delay: random within 2 to 8 sec
    * Input Voltage: 120-240 V; 50/60 Hz with loop through power supply. Voltage rating manually adjustable though a voltage selector on the rear panel. Factory default setting: 220 Vac.
    * Ambient temperature: from 0° to 40°C
    * Relative humidity: from 0° to 90% not condensed
    * Power consumption(max):2A @ 120V; 1A @ 220-240V
    * Power supply loop through: 4 units @ 120V; 8 units @ 220/240V
Mechanical Data
    * Dimensions (WxHxD): 594 x 469 x 505 mm
    * Package size (WxHxD): 700 x 600 x 620 mm
    * Net Weight: 40 Kg
    * Gross Weight: 48 Kg (max)
    * Maximum number of monitors can be stacked: 10 units
« Last Edit: February 28, 2009, 05:34:41 am by uprightbass360 »
ItchyD
  • Last login:July 08, 2017, 03:38:24 pm
Re: Lot of 16 - 25" in-wall monitors [Seattle WA USA]
« Reply #1 on: December 30, 2008, 07:16:13 am »
Not interested in owning any but would like to see some pics! :)
fa001
  • Last login:November 14, 2023, 11:17:08 am
« Reply #2 on: December 30, 2008, 12:31:41 pm »
I could be interested depending on price. Not something I really need but . . .
It would be good to have some pics and the brand / model number to research.
- Fred
« Reply #3 on: December 30, 2008, 02:10:37 pm »
if you decide to ship, I'd be interested in one. I cant drive across the country to pick one up.
BASS!
  • Just have fun.
« Reply #4 on: December 30, 2008, 04:10:29 pm »
Im not going to post photos right now, but they will most likely be $25 to cover my costs. I looked the brand up a while ago, and I know they are german without a website.
BASS!
  • Just have fun.
« Reply #5 on: December 30, 2008, 04:12:27 pm »
They take 15khz vga and can display up to 640x480.
BASS!
  • Just have fun.
« Reply #6 on: December 31, 2008, 04:57:16 am »
5 allready spoken for and thats just one day, anyone else looking for a good monitor?
this is what you are looking at. They look exactly like the ones ive seen by dotronix.
moloch
  • Last login:June 29, 2022, 06:22:19 pm
  • I'm an ill'llama!
« Reply #7 on: December 31, 2008, 10:43:43 am »
I am in Tacoma and if they are $25 each count me in for 3.
« Reply #8 on: December 31, 2008, 11:43:26 am »
sure you cant ship one?  :cry:
BASS!
  • Just have fun.
« Reply #9 on: December 31, 2008, 06:31:33 pm »
eeek these things weigh like 50 lbs which would need a huuuuuge box to keep it safe, and I would have to ship it ups oversize. It could cost around 100 just to ship this bad boy.
SNAAKE
  • Trade Count: (+29)
« Reply #10 on: December 31, 2008, 07:04:01 pm »
wait so how much are you selling the 25" vga for?? if its $25 then I will pay for shipping whatever it cost you through UPS. you can have staples or whatever local shippers pack it in a box for you. whatever it cost you I will be paying for it. need a monitor asap..been thinking about another cabinet for shooters.
« Last Edit: December 31, 2008, 07:13:20 pm by SNAAKE »
BASS!
  • Just have fun.
« Reply #11 on: December 31, 2008, 07:33:04 pm »
I hope to have all of these in my posession by next week. The company will be replacing them with a large plasma wall, and I can't take them until they receive the replacements.
« Reply #12 on: December 31, 2008, 07:41:02 pm »
if you can ship and the shipping isnt TOO bad I might get more then 1. If its cheaper to ship multiple, I might could get snaaakes too and he can drive 4 hours to come get it =p
BASS!
  • Just have fun.
« Reply #13 on: December 31, 2008, 07:43:34 pm »
well hmmmm. I'm going to have to do some calling around for this. I'll keep you posted. I guess I'm not against shipping, I just know how much it usually costs me, and didn't think anyone would even want to bother.
SNAAKE
« Reply #14 on: December 31, 2008, 08:19:47 pm »
Id bother. still better than lcd monitors for gaming. pm sent  :cheers:
I will get 2 and you pick up yours from me  ;)
mainly because I dont drive
« Last Edit: December 31, 2008, 08:23:01 pm by SNAAKE »
BASS!
  • Just have fun.
« Reply #15 on: December 31, 2008, 09:00:36 pm »
allright. That just about sums it up. One left, if I ship all the ones everyone is wanting, and everyone picks up from me that is local.
moloch
  • I'm an ill'llama!
« Reply #16 on: December 31, 2008, 09:51:04 pm »
You can put me down for that last one and I will make it 4 for myself. Just give a couple of days notice so I can get a truck and I will be there with cash in hand.
BASS!
  • Just have fun.
« Reply #17 on: January 01, 2009, 12:48:32 am »
Awesome! K then they are sold out. I'll keep this thread updated and pms sent to everyone once I get them all into my garage. Glad I could do this for everyone, I have always kept my eyes peeled for anything that we as a community can use.
Re: *SOLD OUT * Lot of 16 - 25" in-wall monitors [Seattle WA USA]
« Reply #18 on: January 01, 2009, 10:43:08 am »
so did that include one for me?
SNAAKE
« Reply #19 on: January 01, 2009, 01:42:05 pm »
AND ME??
BASS!
  • Just have fun.
« Reply #20 on: January 01, 2009, 06:12:58 pm »
Yep here is the total tally
snaake - 2
malenko -1
moloch - 4
Local guy - 3
Me - 4
REpc - 2
SNAAKE
« Reply #21 on: January 02, 2009, 02:25:15 pm »
yay  keep us updated  :applaud:
fa001
« Reply #22 on: January 02, 2009, 04:02:02 pm »
I was thinking that as you disassemble the setup, it would be good if you could keep a video cable with each monitor. The far end might not match but the video connection to the monitor would be good to have. I suspect that it is a 9 pin D connector not the "normal" 15 pin. The far end could be hacked to match what ever the user has.
BASS!
  • Just have fun.
« Reply #23 on: January 02, 2009, 06:18:14 pm »
Yeah right now they are connected to the video box ( this 25 year old dinosaur with a huge fan that has been jerry rigged to it) via cheap looking video cables. I think they are standard vga but I may be wrong. The only plug that I know is standard is the scart vga located at the center back of each screen. I will include a vga cable with them, but you will want to either make your own, or buy new ones for good signal quallity.
Franco B
« Reply #24 on: January 02, 2009, 07:32:04 pm »
Nice of you to sort that out Sam.
You lucky, lucky ---daisies---! :)
BASS!
  • Just have fun.
« Reply #25 on: January 03, 2009, 02:13:16 am »
I have been watching in the wings at my work for 2 years for this ;D Glad I could share my good fortune.
« Reply #26 on: January 03, 2009, 02:54:58 pm »
I PM'ed you my addy, lemme know the total shipped. Do you want the $25 now to cover the cost of the monitor?
BASS!
  • Just have fun.
« Reply #27 on: January 03, 2009, 11:09:40 pm »
I want to take them back to the shipping dept before I wrap up and collect money. I hope to be able to do that this week. I am waiting for the guy to give me the word and pull them out of the wall.
BASS!
  • Just have fun.
« Reply #28 on: January 04, 2009, 11:32:24 pm »
Product Features
Features
Picture Tube
    * Dot pitch: 0.8 mm
Electronics
Input/Output
Controls
    * Main switch
Mechanical Data
    * Net Weight: 40 Kg
BASS!
  • Just have fun.
« Reply #29 on: January 05, 2009, 02:26:19 am »
Yeah 105 lbs to all you guys wanting shipping. That will be very expensive. It'll cost like 3-400 to ship these.  I think Im going to go back to local unless you have a freight carrier at your disposal.
Edit: Checked ups ground -104.61 for malenko and snaake for each one. The only think is you can only insure it for 100 or less.
« Last Edit: January 05, 2009, 02:34:13 am by uprightbass360 »
SNAAKE
« Reply #30 on: January 05, 2009, 02:46:41 pm »
 wait so what does it mean? is this a vga monitor that can do 640x480? and how do I get about  hooking up a standard 15 pin vga cable? just wanna hook up an xbox and dreamcast. Id still pay for shipping but I am taking one. someone else can take the other one seeing how expensive shipping is.
BASS!
  • Just have fun.
« Reply #31 on: January 05, 2009, 04:19:29 pm »
If you were going to run your xbox you would have to run vga at 480i and get a vga box for your dreamcast, and hack it to work at 15khz. Just think of this monitor as a standard rez arcade monitor.
BASS!
  • Just have fun.
« Reply #32 on: January 05, 2009, 04:33:41 pm »
Oh yeah, check out ultimarc's adapters, if that is the route you want to go.
SNAAKE
« Reply #33 on: January 06, 2009, 01:39:09 am »
yikes! I am gonna have to pass. its a lot more trouble than I am willing to go through. I am sure someone else them off your hands. sorry  :-\
BASS!
  • Just have fun.
« Reply #34 on: January 06, 2009, 05:19:39 am »
K Once again sold out, someone stepped up:-)
« Reply #35 on: January 06, 2009, 07:19:33 am »
thats more work then I anticipated as well. if you like I can give you the $25 until the unit is sold to someone else. I do appreciate the effort though.
whoamonga
  • Last login:June 04, 2025, 09:24:09 pm
« Reply #36 on: January 06, 2009, 10:28:23 pm »
I work at a museum and we have a similar video wall that utilizes 18 monitor cubes.  We've had it for 15 years and it's definitely showing wear...
Where I'm getting at, is I'm looking for alternatives to the multi-monitor video wall, and you mentioned a large plasma display... Could you tell me anything more about that?
I don't mean to thread hijack, and I'll go away if bothersome!
BASS!
  • Just have fun.
« Reply #37 on: January 07, 2009, 03:25:36 am »
Don't worry malenko, they should sell:-) Thanks a ton though.
@whoamonga - right now I know nothing about what the company is buying, but I tell ya what, when they put it in I will be able to tell you anything you wanna know. I'll keep ya posted ;)
whoamonga
« Reply #38 on: January 07, 2009, 12:32:58 pm »
I sure appreciate that man.  Thank you.
moloch
  • I'm an ill'llama!
« Reply #39 on: January 19, 2009, 01:06:42 pm »
Have you picked these up yet?
