0.106.0.0
Heh, I just looked at my PMs for the first time in forever, and you said 0.108. Some
major differences between the two. However, neither have the -multimouse option I talked about earlier, so just ignore that post. Also, I don't check my PMs that often, so posting here will get faster responses from me.
In mame/mameUI, and windows, all mouse devices, be it a mouse, trackball, spinners, touchpad, and lightguns, are seen as mice. (Lightguns and some touchpads have more info than most mice, but they still have the standard mouse info.) That's why mame only needs -mouse, -joystick, and -lightgun options. Some more info in docs/config.txt file that comes with mame/mameUI.
Just for fun, check if there is a marble.ini file in the ini folder. It might have different settings than the default, and that might be why it's working. You can look directly at the ini files, or try to compair through mameUI's windows. Might want to check the other games' ini files.
Why are you using 0.106/0.108? I'm not saying you shouldn't, or they aren't better for your system, but ... I can help better with more current versions. (Another reason to look in the docs folder, as they should have version currect info on settings.)
