Author Topic: How to use dip switches on Killer Instinct 1 *actual cabinet*  (Read 3868 times)
MyCatSucks
  • Last login:September 25, 2023, 03:57:15 pm
« on: December 10, 2008, 04:09:30 pm »
I am hoping someone can help me with the dip switches on my recent acquisition, Killer Instinct. I have the Manual and it shows the different dip switch settings but does not explain how to change them. I have not been able to find any FAQ on how to adjust dip switches either. The manual also explains that to turn some dip switches on, they must be set to "off".
Do I have to actually change switches on the PCB inside the cabinet? I could not find a way to change them in the Settings menus.
SirPeale
  • Green Mountain Man
Re: How to use dip switches on Killer Instinct 1 *actual cabinet*
« Reply #1 on: December 10, 2008, 04:13:44 pm »
Yes, you change switches on the PCB in the cabinet itself.
« Reply #2 on: December 11, 2008, 07:51:14 am »
see this picture of my burnt out KI2?
the dip switches are in the 2 red plastic areas to left, same spot on a KI1 I believe (Im at work and my broken KI1 board is at home)
