Author Topic: old style sticks that use rubber baseplates, not springs  (Read 2202 times)
Broken
  • Last login:October 22, 2012, 04:29:02 pm
« on: November 29, 2008, 09:21:49 am »
i'm talking about the ones that use the big rubber doughnut baseplates.
i would like to know how to harden the rubber doughnut to get a tighter or stiffer feel on my stick? or a possible really stiff replacemeent.
Kevin Mullins
    • Me on Myspace
Re: old style sticks that use rubber baseplates, not springs
« Reply #1 on: November 29, 2008, 01:06:42 pm »
We used to use black silicone rubber on motor mounts to stiffen them up.
Can be found most any hardware or auto supply store.
I've been meaning to try this out on a pair of Battlezone sticks I have that are shot anyways. (I know there are replacements available though)
So it might be worth trying a thin layer at a time in the "flex" area until desired stiffness is reached. Even thought it might be thinnable so that it could be applied with a small brush.
This is all theory of course, so test at your own risk.
Broken
« Reply #2 on: November 29, 2008, 05:24:13 pm »
thanks for the input.
i dont quite understand what you mean when you say on motor mounts. how would you stiffen it with this?
Kevin Mullins
    • Me on Myspace
« Reply #3 on: November 30, 2008, 04:42:08 pm »
Hehe... yeah, I thought I might throw some people off with the motor mount reference. I'm a mechanic by nature and I was talking about how we used to stiffen up the rubber type engine mounts once they started splitting and such.
We use to get the bigger caulking gun size tubes to fill the motor mounts, but for something like the grommets you would probably only need a small tube to test with.
Like this maybe: http://www.oreillyauto.com/EW3/gpi?id=1574980575
This is more like what we used on the motor mounts:
http://www.oreillyauto.com/EW3/gpi?id=1769083487
I know the stuff in the caulking tubes hardens up more like a solid rubber compound.
I'm thinking a thin layer of similar black silicone rubber applied to the old joystick grommets might stiffen them up as well. And another thin layer could be added as needed to make them more stiff. I was going to try it, but just haven't had a chance to pull my joysticks out of the cabinet yet.
Applying a layer in the thinner "flexible" area of the grommet on each side and let it cure real good before re-assembling them.
It's only a theory of mine, like I said I haven't tried it out yet.
« Last Edit: November 30, 2008, 05:06:17 pm by Kevin Mullins »
SavannahLion
« Reply #4 on: December 01, 2008, 12:52:51 am »
Got a product name? Those links aren't working for me.
Broken
« Reply #5 on: December 01, 2008, 06:36:25 am »
thanks kev but i cant see the links. will anything silicon based be good?
Kevin Mullins
    • Me on Myspace
« Reply #6 on: December 01, 2008, 11:18:53 am »
Weird.... I even tried those links before I posted them. They were just directly to the picture instead of the full page.
 :dunno
Try these two links- they are kinda what I had in mind of trying. Of course something similar from other stores might work and someone else may have a better suggestion.
Small tube: Small tube black silicone
Big tube: Big caulking style tube
Oh, and just a side note when trying to spread this stuff out is to use a slightly wet finger, brush, or whatever applicator of some kind. This helps keep it from sticking to whatever you use to spread it with. Experiment just a little before diving into slapping it on a grommet would be a good idea, just to get a feel for it.
« Last Edit: December 01, 2008, 11:26:56 am by Kevin Mullins »
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #7 on: December 01, 2008, 05:32:23 pm »
These are often called grommets (most common name here), though atari called them bellows.  Neither are the best terms (look up the definitions), and IIRC some (most?) were actually vibration isolation mounts used for a very different purpose.
There were a few different joysticks that had them, and different models of grommets were used by the different brands.  I'm not sure about hardening them, but GGG has replacements for happs 49-way sticks.  Sometimes you can find wico NOS grommets (ponyboy had 'em for a while, but looks like he's busy with RealLife ATM.).  A couple basic "what is grommet?" threads: link 1, link 2.
What model joystick are you trying to refurbish/repair?
Robin
Knowledge is Power
Kevin Mullins
    • Me on Myspace
« Reply #8 on: December 01, 2008, 06:11:47 pm »
You're right.... I forget that they use the term "bellows" for some of these as well.
The ones I have been visualizing are like the ones for Battlezone and such like these:
http://www.wizzesworkshop.com/cart/product.asp?intProdID=19
And I was thinking that by applying a layer of silicone in the shallow "flexible" area might work to stiffen or revive a torn one.
Broken
« Reply #9 on: December 20, 2008, 03:07:32 pm »
its a suzo... the old school suzos.
http://www.highway.net.au/parts/joysticks/4235_1.html
« Last Edit: December 20, 2008, 03:17:07 pm by Broken »
Broken
« Reply #10 on: December 22, 2008, 08:52:42 pm »
http://74.125.45.132/search?q=cache:NyKRxgJzHaAJ:www.happcon trols.com/vending/vendpart/ap/automatic_3.htm+suzo+grommet&a mp;a mp;hl=en&ct=clnk&cd=6&gl=uk
1:    Vending Parts Automatic Products
   Item Number: 24400041
   Grommet .47dia Rmi
   Item Number: 24400067
   GROMMET PLUG .87 DIA
« Last Edit: December 22, 2008, 08:58:22 pm by Broken »
Broken
« Reply #11 on: December 26, 2008, 02:56:21 am »
bump
Broken
« Reply #12 on: January 04, 2009, 04:52:00 am »
bump
