Author Topic: Nanao MS720L (Kortek) - Sync Problems ?  (Read 11941 times)
grantspain
Re: Nanao MS720L (Kortek) - Sync Problems ?
« Reply #40 on: November 23, 2008, 05:06:49 pm »
how do you know which wire is the sync and which is the ground
DarkSide
  • Last login:August 03, 2023, 05:15:13 pm
« Reply #41 on: November 23, 2008, 05:18:26 pm »
White with black stripes is ground, black is sync.
I dont know why, but when following the wires it looks like sync is connected together with the +12 volt, but that was working fine with the hantarex.
grantspain
« Reply #42 on: November 23, 2008, 05:26:59 pm »
that don't sound right to me and i think the sync is the white/black wire and the ground is the black
show me where you think the +12 is connected to the sync
DarkSide
« Reply #43 on: November 23, 2008, 05:30:39 pm »
Black is sync.
Can you see the yellow wire in the connector, thats sync from then gameboard, its connected together with a blue and white wire, the blue runs to at few lamps in the control panel, and its connected to +12 volt from the powersupply.
The black wire where sync is connected is also comming from the lamps.
« Last Edit: November 23, 2008, 05:32:18 pm by DarkSide »
grantspain
« Reply #44 on: November 23, 2008, 05:37:57 pm »
here's the problem alright
yellow is almost always a +12 line and it makes sense it goes to the coin door bulbs
black is always a ground and also makes sense
your sync should not connect to +12
please disconnect all the video signal loom from that connector and then send another photo
DarkSide
« Reply #45 on: November 23, 2008, 05:42:08 pm »
Thats just not like it is in my cab.
Yellow is sync from the gameboard, and black in the connector is also sync, and im sure checked with my scope.
I dont know why its made like it is, but if i connect the hantarex there is picture with the wires connected as is.
Black is ground, comming from the lamps, its a wiring nightmare.
I just need to get a picture on that monitor, take a few pics and redo all the wires in the cab.
grantspain
« Reply #46 on: November 23, 2008, 05:46:25 pm »
well i think the black/white is your sync and the black next to it is the video ground
you do not have two syncs
DarkSide
« Reply #47 on: November 23, 2008, 05:58:03 pm »
grantspain
« Reply #48 on: November 23, 2008, 06:02:52 pm »
still think i am correct
have you tried that yet?
DarkSide
« Reply #49 on: November 23, 2008, 06:10:51 pm »
Just tried.
With sync on white/black, and ground on black, i dont even get a picture on the monitor.
grantspain
« Reply #50 on: November 23, 2008, 06:12:34 pm »
right ok,there is some nasty wiring in there thats for sure
now reconnect the video ground to white/black and leave the sync off
DarkSide
« Reply #51 on: November 23, 2008, 06:13:39 pm »
Done, what now ?
Yellow must be sync from the gameboard then, i hate bootlegs PCB's
grantspain
« Reply #52 on: November 23, 2008, 06:22:47 pm »
this is the problem now,you see
going on the theory that the sync must be on the connector with the rgb then we must look at that
strange for the sync to be away from the others and if its +12 reading then its not sync for sure
i would look at some of the other pins on that connector(not the red as i think thats +5 and not the black as i think thats ground)
there are many other pins there,meter them and see if any of them are getting signal and what level
trouble with this being a copy board is that it don't match the original wiring
DarkSide
« Reply #53 on: November 23, 2008, 06:26:52 pm »
There is just one problem.
If yellow isn't sync, why did it work with the hantarex monitor ?
A monitor doesn't run without a sync signal + my scope says that yellow is sync.
grantspain
« Reply #54 on: November 23, 2008, 06:30:06 pm »
well if your sync is yellow it should not read +12 volts or be connected to anything apart from the sync video input
DarkSide
« Reply #55 on: November 23, 2008, 06:33:09 pm »
I dont know, dahm bootleg ---steaming pile of meadow muffin---.
I still think that the new monitor is broken
grantspain
« Reply #56 on: November 23, 2008, 06:34:30 pm »
so have you connected the sync to yellow with no other wires connected
good point about your old monitor wiring btw
DarkSide
« Reply #57 on: November 23, 2008, 06:38:55 pm »
Yes i did try to connect the yellow directly to the white sync wire from the chassis, didn't change anything.
Guess i need to connect my mame pc again, and then try to get a good picture on the monitor just so i can see if it really works.
grantspain
« Reply #58 on: November 23, 2008, 06:41:36 pm »
yes good idea,you have a nightmare scenario whereby the two main items are not known to be 100% working
proving the monitor with another video source is the right way to go with this
whats the story of the bootleg board?
DarkSide
« Reply #59 on: November 23, 2008, 06:47:16 pm »
Don't know much about that board, there is a picture here: http://yousuck.dk/DSC02801.JPG
I'm gonna wire up a vga to arcade monitor cable tomorrow, thanks for your help so far :)
grantspain
« Reply #60 on: November 23, 2008, 07:03:30 pm »
just make sure you feed the monitor a 15khz signal or you will probably kill the hot
you can feed the monitor a 31khz signal for a few seconds but no more,that may be just enough time to see if you get a sync lock but obviously you will have a double image
DarkSide
« Reply #61 on: November 24, 2008, 05:18:54 am »
No problem getting a sync lock when using the mame pc..
http://yousuck.dk/DSC02802.JPG, but the picture looks pretty bad, maybe the tube is dying ?
grantspain
« Reply #62 on: November 24, 2008, 06:26:41 am »
hmmm,i know the nanao and hantarex have different signal input ranges
the hantarex can accept 1v to 3v signal whereas the nanao only accepts 3v
perhaps this is the problem,also i know that if you use a nanao from a vga card using soft15k then you also need a video signal amp to get a good picture
i think you getting closer to the problem,this could be a simple matter of the signal not strong enough for the sync
now you have to decide what to do from here-options being getting a video amp(more expense and not guaranteed to work) or using a different monitor
DarkSide
« Reply #63 on: November 24, 2008, 06:37:16 am »
I guess the only option is to trash that Sega Hang on, a new monitor is not an option, its hard getting arcade monitors in denmark.
Unless if you can tell me if i can use my old hantarex MTC900E chassis on the new tube ?
grantspain
« Reply #64 on: November 24, 2008, 06:42:01 am »
depends on the yoke reading,you would need to meter out the yoke
horizontal yoke is red and blue
vertical yoke is yellow and green
do you have the old 900 tube to compare to?
grantspain
« Reply #65 on: November 24, 2008, 06:43:36 am »
you could also just try upping the 5volts on the power supply so that you get 5.15 at the board as i have once seen this cure a boot video problem similar
DarkSide
« Reply #66 on: November 24, 2008, 06:45:30 am »
Yes, the old tube is a VideoColor A51-421X, and the new is a Samsung 5108B22
Upped the 5 volt to 5.18, still no luck.
« Last Edit: November 24, 2008, 06:55:42 am by DarkSide »
grantspain
« Reply #67 on: November 24, 2008, 07:04:54 am »
right o.k then the next step is to read the yoke,do you have a multimeter?
even better do you have an inductance meter?
what you need to do is set your multimeter to ohms and read the red and blue of the yoke for horizontal
and read the yellow and green for vertical on the new nanao tube
then the hantarex is different colours but you you will see which pair is which and you should get similar readings
also you need to check the tube neck pinout and shape are the same
grantspain
« Reply #68 on: November 24, 2008, 07:08:35 am »
To enable you to match a chassis to a yoke you will need to have two types of meter,a standard multimeter for the resistance and an lcr/inductance meter for the inductance
Guessing yoke readings is not a good thing,an unmatched chassis will fry the horizontal output stage and in the extreme could kill the yoke
Lcr meters are always available on ebay at very reasonable prices
You need to read both resistance and inductance of each of the two parts of the yoke,vertical and horizontal.
Normally you find red and blue is the horizontal coil,green and yellow the vertical
Therefore you would set the multimeter to ohms and place one probe to the red and the other probe to the blue to give horizontal resistance and so on.
DarkSide
« Reply #69 on: November 24, 2008, 07:12:42 am »
Only got a multimeter, and its a no go, H is 3.0 on both yokes, but V is 14.8 on the Videocolor, and 58 on the samsung.
Then my only option is getting that Kortek chassis working with the Sega board.
« Last Edit: November 24, 2008, 07:14:32 am by DarkSide »
grantspain
« Reply #70 on: November 24, 2008, 07:23:43 am »
so thats a high impedence yoke on the samsung
the chassis would need modification to fit
so maybe a way to boost the sync signal is the way to go now
you know the only time i saw a similar problem was when i had a k7000 chassis and the 50/60 hz pot was slightly out
now i wonder but doubt that the horizontal sub pot will make any affect
DarkSide
« Reply #71 on: November 24, 2008, 07:34:04 am »
No effect on adjusting the h sub pot.
grantspain
« Reply #72 on: November 24, 2008, 10:41:59 am »
i am out of suggestions,all i can think now is some kind of sync boost
there are a few peeps on this forum that i think could advise-ken layton,qrz and rickn
maybe worth posting a new thread
DarkSide
« Reply #73 on: November 24, 2008, 10:44:28 am »
Maybe ya.
Thanks for all your help, im gonna try a new thread, on how to boost the sync signal.
