Author Topic: I know this was asked by someone, but I can't find it  (Read 1557 times)
Shieldwolf
  • Last login:November 16, 2020, 12:48:53 am
  • SpearShield.com
« on: June 18, 2003, 02:13:58 pm »
If I have a working marvel vs capcom 2 complete and I want to keep it to play games like snk and other newer arcade games is it possible to setup a mame computer and switch between the two? I know anything is possible, but is it realistic? If so how would you do it?
Tiger-Heli
    • Tiger-Heli
Re:I know this was asked by someone, but I can't find it
« Reply #1 on: June 18, 2003, 02:19:45 pm »
www.ultimarc.com  You'll probalbly want a J-PAC and an arcade VGA, but I'm not really up on this.
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #2 on: June 18, 2003, 02:34:36 pm »
see tiger-heli's post... did you mean switch between them instantly or be able to swap manually from pcb to MAME and back again.
If you meant instantly (without going into the back of the cabinet each time) you'd need to do some research on multi-jamma kits/projects.
Rampy
Shieldwolf
  • SpearShield.com
« Reply #3 on: June 18, 2003, 02:46:44 pm »
Well I just found a really great marvel vs capcom 2 game in mint condition really cheap. I want to still build a cabinet but don't have room for both so I wanted to find out if i could put mame in my capcom 2 cabinet and switch on the fly. I wasn't even sure if it was possible. I will do some research, but I thought if anyone knew I if i could do it before I got too excited.
IIOIOOIOO
  • Last login:August 04, 2003, 02:18:12 pm
« Reply #4 on: June 18, 2003, 03:00:31 pm »
If you want to open it to switch, just wire all of your stuff up to a standard harness, then you can swap the edge connector between the real game and the JPAC.
Otherwise, you're kind of out of luck, unless you want to drop $200 on a nice electronic JAMMA switcher, or make one out of a printer-selector box.
Shieldwolf
  • SpearShield.com
« Reply #5 on: June 18, 2003, 03:13:22 pm »
so, if i got marvel vs capcom for 250 mint, bought the switcher put my mame stuff in that cabinet. I would be spending about 500 dollars vs 1700 for new mame cab?
Hoagie_one
  • Um....whats a cabinet
« Reply #6 on: June 18, 2003, 03:19:41 pm »
i bet even cheaper if you have some electronics knowhow
Tiger-Heli
    • Tiger-Heli
« Reply #7 on: June 18, 2003, 03:38:11 pm »
Not hardly, I haven't checked the prices, but cabinet is 250 and switcher is 200, plus about $80 for the arcade VGA, plus about $80 for the J-PAC, plus the computer itself, plus shipping, plus wiring and connectors, plus time (I think you're over $500).
rampy
  • *shrug*
« Reply #8 on: June 18, 2003, 05:32:45 pm »
Is marvel vs. Capcom 2 emulated in mame?
if so... why ever switch?
Rampy
PS pardon my ignorance as to not knowing ALL the 4000 games in mame
Tiger-Heli
    • Tiger-Heli
« Reply #9 on: June 18, 2003, 05:36:33 pm »
I only see Marvel vs. Capcom 1, give it six months, though!  (And no, I don't have inside information :-)
That's what front ends are for!!!
paigeoliver
  • Awesome face!
« Reply #10 on: June 18, 2003, 05:36:45 pm »
Eh, any switching solution you devise would have to either provide a load on the arcade power supply, or turn it off when you are running mame. Those switchers will go up in smoke real quick if you run them with no load.
I say just pack up yr Jamma board all nice and protected inside, and run it in Mame instead, you may want to have yr frontend default to that game upon bootup.
Pyronious
  • Last login:June 04, 2021, 09:52:25 pm
  • Klatuu... Verata... Necktie.
    • Pyronious.com
« Reply #11 on: June 18, 2003, 06:27:40 pm »
Marvel vs. Capcom 2 is not emulated in MAME, and is unlikely to be emulated any time soon, as the hardware (Sega Naomi) is a heavy-duty polygon pushing (3D) machine.
To do what you want to do, you will need a JPAC and ArcadeVGA to connect your PC to the JAMMA cabinet.  Then you will need a MultiJAMMA, available from:
http://www.multigame.com/jamma.html
Have fun!
« Last Edit: June 18, 2003, 06:29:17 pm by Pyronious »
