Author Topic: Frontend issues while running at 632x264  (Read 1721 times)
moloch
  • Last login:June 29, 2022, 06:22:19 pm
  • I'm an ill'llama!
« on: November 20, 2008, 12:47:45 pm »
I am setting up a MAME machine and the "Largest" resolution that I can get to come up on the Arcade monitor is 632x264. I am using Soft 15KHz.
I would like to use Mala, but I have more experience with MameWah.
I cannot find any layouts for 632x264.
Is there something that I am overlooking?  :dunno
gonzo90017
Re: Frontend issues while running at 632x264
« Reply #1 on: November 20, 2008, 03:25:15 pm »
That's an odd resolution. You would have to make your own or modify one of the existing layouts using the Mamewah Layout Editor. Here's a small tutorial I made in case your not familiar with the Layout Editor. Just double click on it to start playing it.
http://www.mediafire.com/?aewmljny1mx
moloch
  • I'm an ill'llama!
« Reply #2 on: November 20, 2008, 04:01:25 pm »
I agree that it is an odd resolution, but am I missing something that is forcing me to use that one. When I switch to 640x480 the screen will not stabilize.
moloch
  • I'm an ill'llama!
« Reply #3 on: November 20, 2008, 05:15:40 pm »
thanks for the movie link
I played around a lot more and I got the screen to work at 640x240 which seems to be a more common setting.
Now though when I start a game the resolutions that it picks do not seem to work.
gonzo90017
« Reply #4 on: November 21, 2008, 01:40:41 am »
I'm not familiar with soft15khz since I use a pc monitor. You might have your resolution set to "Auto".
Try asking in the Soft15khz thread over in the Video Forum.
moloch
  • I'm an ill'llama!
« Reply #5 on: November 21, 2008, 01:49:05 am »
I am pretty convinced it is not a soft 15KHz issue.
Ummon
  • Trade Count: (+13)
« Reply #6 on: November 23, 2008, 12:23:18 am »
No, but it might be a mame ini issue.
Yo. Chocolate.
Stephen Hawking
moloch
  • I'm an ill'llama!
Front end issue fixed - Pac-Man and varients getting bottom of maze cut off.
« Reply #7 on: November 23, 2008, 12:30:59 am »
so just an update.
I have pretty much fixed all of the problems now except for one.
When I am running games like Pac-Man or Ms. Pac-Man the bottom of the maze seems to be below the visible bottom of the screen. I cannot see the bottom 1/4 or so of the screen - this happens only when the actual game starts.
I have been using the res-tool to create resolution ini files for every game. I have gone in and modified those ini files with all kinds of variations and it still cuts off the bottom of the maze.
Other games seem to play fine I tried out about 15 or so other games. For now it seems like just the Pac-Man and Pac-Man type games seem to have this issue.
Any ideas?
(Changed subject line to reflect change in issue)
Ummon
« Reply #8 on: November 24, 2008, 09:03:30 pm »
What res are you running for those?
Yo. Chocolate.
Stephen Hawking
moloch
  • I'm an ill'llama!
« Reply #9 on: November 24, 2008, 09:41:36 pm »
Here is the text of the .ini that I am using to make them work:
direct3d                1
resolution 240 x 392
