Author Topic: No bearing with arbor bit? Confused...  (Read 2349 times)
Epyx
  • "You're an oddity"
« on: November 15, 2008, 12:22:39 am »
I purchased a Freud 60-100
http://www.homedepot.ca/webapp/wcs/stores/servlet/CatalogSearchResultView?D=973244&Ntt=973244&catalogId=10051&langId=-15&storeId=10051&Dx=mode+matchallpartial&Ntx=mode+matchall&recN=0&N=0&Ntk=P_PartNumber
In some pictures in this forum I notice a bearing piece mentioned and pictured...the 60-100 came with the shaft, nut and about 7 washers but no bearing is that normal? Or is the bearing part of the shaft? Do i buy it seperately?
Any assistance for this router noob would be appreciated (just picked up the router today and 3 wing 1/16" will be picked up tomorrow)!
Last Project
Epyx Tutorials:
Tutorials
Franco B
Re: No bearing with arbor bit? Confused...
« Reply #1 on: November 15, 2008, 05:09:46 am »
They don't always come with bearings, I know mine didn't. You will need to purchase one separately. Any BB with a 1/4" inner race will do. I would get a sealed one if i was you, something like [this].
Epyx
« Reply #2 on: November 15, 2008, 12:11:08 pm »
Awesome FrancoB...thanks much! Saves me an extra trip.
Last Project
Epyx Tutorials:
Tutorials
Chadwick
  • Last login:January 11, 2010, 03:23:34 pm
« Reply #3 on: November 17, 2008, 01:53:56 pm »
The bearing is sold separately.  You need a ball bearing with 5/16" Inside Diameter and 7/8" Outside Diameter.  This will give you the standard 1/2" depth of cut.  It should run you about $4.00 give or take a buck or two.
