Author Topic: djurests mame - I need info about coin mechs?  (Read 1291 times)
djuret
  • Last login:August 31, 2014, 08:42:13 am
« on: October 20, 2008, 11:21:37 am »
Hi!
I've finally decided to build my own MAME-cabinet.
I will probably order my parts from happcontrols.com.
I've read quite alot but have one question regarding this coin-mech.
http://www.happcontrols.com/coindoors/42303900.htm
Does it have a front? should i buy a coin-front and then install this coin-mech behind it?
If so, how do I know what fronts are compatible with that mech.
Ken Layton
  • Guru
  • Technician
Re: djurests mame - I need info about coin mechs?
« Reply #1 on: October 20, 2008, 11:27:35 am »
That's a raw coin mech/coin chute. You need a coin door to put it in.
djuret
« Reply #2 on: October 20, 2008, 11:50:13 am »
Assuming I buy this coin-mech and a fitting coin-door.
Is this mech ready to be wired to a I-PAC?
Or do i need to install a coin-switch which I will wire to the I-PAC?
