Author Topic: Mala Layout Question - Definable1  (Read 3585 times)
cmoses
« on: October 17, 2008, 04:41:30 pm »
Is definable1 only available in the MAME layout?  I see where you can set it up in the MAME portion, but it does not show up under options in the Other EMU configurations.
I am trying to convert a MAMEWAH Nintendo layout and it has a space for cartridge, box, and two snap shots.  I am using marquee for box, control panel for cartridge, snap/title for snap 1.  I tried to use video for the second snap, but it did not work.  Guessing that it is looking for a .avi file.  So I setup definable1 to be the second snap under the MAME options.  I do not get anything displayed in the layout though.  I swapped the snaps and they both work, but only under snap/title, nothing ever displays under definable1.
Any help would be appreciated.
« Last Edit: October 17, 2008, 04:45:32 pm by cmoses »
loadman
  • Moderator
    • MaLa
Re: Mala Layout Question - Definable1
« Reply #1 on: October 17, 2008, 11:47:26 pm »
Definables for Emu's other than mame will be avaliable in the next version.. I Hope so anyway.
I have half implimented it so far in the beta version  ;)
cmoses
« Reply #2 on: October 18, 2008, 12:53:03 am »
Good to know, and thanks for all your hardwork.
TheShanMan
    • My Arcade (updated 1/30/13)
« Reply #3 on: October 18, 2008, 02:13:03 am »
I'm looking forward to this! Thanks loadman!
loadman
  • Moderator
    • MaLa
« Reply #4 on: October 18, 2008, 04:21:32 am »
I have the definables displaying in the Other Emu layouts already. That was the easy bit.
Decisions I am yet to make are:
1) Am going to have common directory paths for all 'other emu's' or paths per 'emu' yet..
Does anyone care?  :dunno
2) Where to save this data?. The emu files *.mle probably won't be backward compatible after this. I could save in the mame.ini if all other EMU's shared the same the same directory paths I guess  :dunno
Just my current pondering.....
« Last Edit: October 18, 2008, 07:26:30 am by loadman »
TheShanMan
« Reply #5 on: October 18, 2008, 01:10:09 pm »
I think it's better to have it per-emu. I think doing it "right" is more important than being able to go back to a prior version of mala. I can't remember if mala has an actual installer. If so, you might want to have it back up config files on upgrade. If not, at least put a warning by the download link. That's my 2 cents.
shock_
  • Last login:January 30, 2020, 06:23:29 pm
  • In Brisbane, it's GMT+10 all the time.
« Reply #6 on: October 21, 2008, 05:50:58 am »
Wow, I want this feature too!
My head hurts too much right now to add any value with discussions about the architecture... I'm sure you'll work it out though loadman :)
Thanks again
loadman
  • Moderator
    • MaLa
« Reply #7 on: October 21, 2008, 06:14:54 am »
It's happening and it works allready.   ;)
Just working through methods of saving the new config the 'right way' so that I don't screw up peoples current emu settings.
WIP PIC
« Last Edit: October 21, 2008, 06:16:47 am by loadman »
