Author Topic: (yet another) PC power-button topic  (Read 1541 times)
TelcoLou
  • Four score and seven years ago our fathers brought forth on this continent, a new nation
  • Last login:October 14, 2010, 01:28:19 am
  • Playing video games since 1977
« on: October 08, 2008, 02:20:14 pm »
OK,
I just got a Smart Strip, and it works perfectly right out of the box. My next step was to enable the "power-the-pc-by-pressing-any-keyboard-button" option from within the BIOS. I have 2 settings under PS/2 Keyboard power on; "disabled" or "any key".
Unfortunately, it doesn't recognize ANY button presses (I'm assuming because it's a USB keyboard converter IPAC thingy, and .. well USB isn't turned on yet, because the PC is off).
SO ...
I wanted to go for the scary task of running wires up to a dedicated power button, located on my CP. My questions are;
• What type of wires should I use?
• Any specific button recommendations?
• Can I get away with splicing the wires instead of soldering?
I'll be going to Radio Shack to get the parts, and any advice/tips would be most appreciated.  8)
So a leper walks into a bar and as he gets his beer, a finger falls off. The bartender who is serving him turns and pukes all over the place. The leper, feeling bad, says, "Was it my finger falling off?" The bartender turns to him and says, "No, it's the guy dipping chips into your back."
thatitalian
  • The Revolution Is Coming...
Re: (yet another) PC power-button topic
« Reply #1 on: October 08, 2008, 02:27:04 pm »
I did this and surprisingly it is relatively easy (now that I know how) to do it this way.
To answer:
20 gauge wire is good, that's what I am using in my CP.
The button doesn't matter, as the wires will be connected to a microswitch, if it is a normal pushbutton. Just make sure the button is out of the way, you don't want to hit it during a frenzied game of Marvel vs Capcom!
You can splice! But why not splice and solder!? Just to be safe!
TelcoLou
« Reply #2 on: October 08, 2008, 06:44:46 pm »
Thanks for the reply. If I soldered wires directly to the leads on the PC's power button, then to another button, would it work? I'm afraid of messing something up on the MOBO  :o
thatitalian
« Reply #3 on: October 08, 2008, 07:09:14 pm »
Do you mean the power button on your PC's case? If so yes, it will work, just make sure they are the right way round. I don't think anything will go wrong if they are not as you can simply swap them round on your microswitch.
TelcoLou
« Reply #4 on: October 08, 2008, 07:31:09 pm »
Cool! Thanks again :)
