Author Topic: Decasing A Dell Monitor?  (Read 1992 times)
lettuce
  • Make It So!
« on: October 07, 2008, 10:53:44 am »
Does anybody have a guide on how to decase a dell 1905fp flatpanel monitor. Cant see an easy way to get the case apart with out cracking it???
« Last Edit: October 09, 2008, 07:00:22 pm by lettuce »
lettuce
  • Make It So!
Re: Decasing A Dell Monitor?
« Reply #1 on: October 09, 2008, 07:00:33 pm »
Anyone?
evilfuzzle
  • Last login:November 26, 2008, 03:17:48 am
« Reply #2 on: October 09, 2008, 09:50:19 pm »
by flatpanel i am assuming it is an lcd screen. i think you will find that cracking it open is your only option, i decased my lcd screen when it broke (it was out of warranty) and i discovered after hours of tugging prying and crying that inside were several clips that could not be opened from the outside, the manufacturers make it so that it can be sealed really easily but not opened without destroying the case so they would have to pay out less warranties, crack it open!.
being the optomistic person that i was i throught that it would simply be held together with screws and nothing more...WRONG :banghead: i could have saved hours.
take my advice.. decide whether or not you would be okay with the chance of destroying your screen and voiding the warranty before you attempt the decase.
have fun  ;D
richms
  • Last login:January 07, 2025, 06:42:57 pm
  • s92a sucks
    • richms.com
« Reply #3 on: October 13, 2008, 07:29:19 am »
A credit card is often enough to unsnap those without leaving marks if you need to open something like that. Just dont use a good one ;)
KeithD
  • Last login:October 19, 2008, 07:57:26 am
  • I HAVE built my own arcade controls!
    • Nameless Cab
« Reply #4 on: October 13, 2008, 08:02:44 pm »
I do this frequently at work, and all I can say is, "Thank the Lord for the Swiss Army!" :)
Take off the stand, and gently (!) pry the two case halves apart. Look to see if there are any screws holding it together first, of course.
K
You laugh because I am different;
I laugh because you are all the same.
