Author Topic: Multi-purpose bartop  (Read 9591 times)
glonq
  • Last login:September 09, 2009, 02:24:24 pm
« on: September 29, 2008, 02:13:23 am »
This weekend, I started building a bartop that will primarily serve as a mame cab, but could also be a decent TV or PC.  My main concern was to accommodate the fact that you'd expect a different viewing angle for each role (straight for TV or PC, tilted back for gaming).  The design constraint is the fact that I'm not a mechanical engineer, nor do I have aspirations of becoming one.  I'm sticking to noob-friendly woodworking.  Here's the plan:
Cab in 'straight' orientation:
Cab in 'tilted' orientation:
Here's the guts.  3/4" MDF + 2x2 frame:
Note that the front panel (acting as an LCD bezel) will actually be made of wood, not plexi as shown.
« Last Edit: September 29, 2008, 02:25:04 am by glonq »
glonq
Re: Multi-purpose bartop
« Reply #1 on: September 29, 2008, 02:22:59 am »
After a couple clumsy attempts at making straight cuts using a skill saw or a jig saw (w/ guide), I gave up and hauled all my MDF to a workshop that has a table saw and other proper tools.  Wow, having the right tools for the job makes all the difference!
Clamping and gluing the frame onto the front panel:
Fully assembled CP next to a fully cut/routed front panel:
For sound, I'll sacrifice a couple low-end dell speakers:
Installed the under-mount joystick kit from GGG:
Cut the piano hinge using a jig saw + metal blade:
Here's how the cab will look in 'straight view':
Here's how it'll look in 'tilted' view (excuse the bad angle.  and the hairy arm :P):
NiN^_^NiN
« Reply #2 on: September 29, 2008, 06:57:08 am »
thats a smart idea with the angles for tv then arcade nice i like it :)
Good job keeping an eye on this
IG-88
« Reply #3 on: September 29, 2008, 07:02:50 pm »
Very cool!  :cheers: This gives me a few ideas for my own. What kind of dimensions are we looking at? (width, height & depth)
Also are you going to have a DVD player coming out the side maybe? That'd be sweet.
-HarumaN
glonq
« Reply #4 on: September 29, 2008, 07:12:18 pm »
Roughly 25" wide, 21" high, 16" deep.  Big enough to fit a 22" LCD plus a bunch of PC parts.
I still haven't decided if (or where) the DVD player will be exposed.
Bender
« Reply #5 on: September 30, 2008, 09:39:42 am »
I really like the design :applaud:
I know it's a little late but you could angle the left and right edges as well so you could do horizontal AND vertical orientation
gonzo90017
« Reply #6 on: September 30, 2008, 04:57:10 pm »
Smart design. Looking forward to seeing your progress.
glonq
« Reply #7 on: October 09, 2008, 01:03:13 am »
Slow progress this week:
Since it's cold and windy outside now, I built a ghetto-style enclosure in the garage for spraying the primer:
After spraying the primer, I realized that I hate spray painting.  Eff it, I'm gonna roll this sucker.  Latex too, since oil is a PITA.
3 primer + 3 paint + 3 clear coat = durable finish?
A test fit of all the panels before I start gluing and screwing.
A long weekend approaches (Canadian Thanksgiving), so I hope to finish off the CP (buttons, sticks, mini-pac), and then resume work on the cab.
glonq
« Reply #8 on: October 10, 2008, 12:14:04 pm »
Halfway through wiring up the mini-pac harness (a nice time saver!)
The finished product.
Time to finish the cab now... :P
koinsatx
  • Last login:April 26, 2021, 11:46:31 am
« Reply #9 on: October 11, 2008, 10:38:14 am »
Looking really good.
 So did you use latex based paint?  and then clear coat it?
 Any thoughts on this?
 I used latex based and am not happy with the durability of it I think.
Kevin
slasherman
  • Last login:September 12, 2022, 03:53:37 am
« Reply #10 on: October 11, 2008, 03:49:11 pm »
What about also making it tilt vertikal. Nice idea by the way
glonq
« Reply #11 on: October 11, 2008, 07:28:24 pm »
Kevin
I'm sure the durability will be okay for the cab.  Not quite sure about the CP, though.  If 3 coats of polyurethane aren't enough, then I'll strip the sucker down and resurface it with shelf paper or vinyl or linoleum or something.
glonq
« Reply #12 on: October 20, 2008, 01:32:31 am »
Back to the cab.  I wanted to make more progress on this, but a car decided to slam into my bike and dog and myself this week, and that slowed me down a bit.  :dizzy:
Fully assembled (glued and screwed).  Monitor seems to fit nicely.  Piano hinges fit well enough.
Painting the cab
glonq
« Reply #13 on: November 09, 2008, 02:42:36 am »
No updates for a few weeks, but lots of progress.  The thing is all painted now, and I stuck a $200 barebones PC inside.  I haven't put the hinged top/back panels on yet.
Here's the guts:
This is the cab in upright mode, pretending to be a PC:
...and here it is tilted back, running Hyperspin and my fave classic game, Elevator Action:
Okay, I'm definitely throught the woods on this project.  My to-do list includes:
- Use piano hinges to attach top and back panels
- Build a little panel on the back for power cable, USB hub, power button, etc
- Decide on a front end (check out Mala and others)
- Figure a way to add sturdy handles that don't look crappy
- roms roms roms.
- Turn it into a Vista Media Center (TV tuner, remote control)
- Repeatedly spray all painted surfaces with clear coat until the bottle runs dry
FYI, cab specs are:
- AMD Sempron
- Geforce 6100 (onboard)
- 2GB RAM
- 500GB HDD
- Vista ultimate
- Acer 22" LCD
- Mini-pac encoder
- Hauppauage PVR-150 tuner
- Microsoft MCE remote
  • Last login:January 25, 2026, 10:26:13 pm
« Reply #14 on: November 09, 2008, 06:50:47 am »
looking real good!
Clever idea with the dual purpose too.
 :applaud: :applaud: :applaud:
