Author Topic: U-track movement?  (Read 1096 times)
pupu
  • Last login:June 04, 2011, 05:35:46 pm
U-track movement?
« on: September 26, 2008, 03:53:32 pm »
I have my trackball set up but I cant get it to go in a straight line.  It seems to move just fine, but I can not move it in a straight line by moving the ball in a straight line.  It moves where I want it to, but it takes a lot of correction.  I only have it hooked up to a pc now to make sure it worked, so I have not messed with any setting in Mame, but I assume it should move like a mouse? Been along time since I used a trackball.
Nevermind, I got it.
« Last Edit: September 26, 2008, 05:00:30 pm by pupu »
clickhea
  • Last login:August 09, 2019, 07:33:40 am
Re: U-track movement?
« Reply #1 on: September 26, 2008, 05:34:13 pm »
i have this exact problem as well
it moves up and down fine
but left and right it sorta moves up and left  up and right
howd u fix it?
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« Reply #2 on: September 26, 2008, 06:54:36 pm »
Usually because it needs bedding-in, is mounted at an angle or needs fine-tuning.
pupu
« Reply #3 on: September 26, 2008, 08:25:04 pm »
I hate to admit this, but when I was mounting it, I mounted it even and square to the panel, when in fact it mounts with the "arrow" pointing straight up.  I did not notice the arrow till after I had it mounted in the panel.  I have to remount it now.  That was my problem, so was just my bad for not paying attention.
