February 11, 2026, 03:53:19 am
the problem is, the admin panel has to be about 3/4 in from the edge
i tried a big admin panel, and it looked very out of place which is why i wanted to stay with somthing smaller.
is the problem that there is not enough room for the back side of the buttons because its too close to the TV?You can always try taking the back of the TV case off (watch the flyback transformer!) and give you a little more space up front to squeeze the buttons in.
what lexan thickness should i go with for the tv area?
