Author Topic: how to do it, set it up, 1st steps, help  (Read 1463 times)
G1zm0
  • Last login:October 05, 2020, 06:57:58 am
  • cute by day, devil by night
« on: September 23, 2008, 10:10:39 am »
ok got me roms all in place and the fe working (mala), now what i need to know is.
i want to hide windows as per wiki entry, but if i want to add roms, emus or tinker with the innings of the emus how do i do this?
if i follow guide and make 2 accounts as it says, how do i log in to second account to change things if it boots straight to fe with no cursor?
also i tryed the 2 accounts  but windows gets to the point where it should pop up the names then hangs , took about 3 resets to get it to boot to this screen, when i delete the accounts it works.
this is only snaggs on this machine that is bugging me.
still other machine snaggs to sort out but thats another post :)
Ginsu Victim
  • Comanche, OK -- USA
Re: how to do it, set it up, 1st steps, help
« Reply #1 on: September 23, 2008, 10:12:30 am »
I don't know about Mala, but I know in Mamewah I can exit to windows instead of shutting down. Surely Mala has that. If I need to work on my system, I start it as normal, then exit Mamewah into Windows.
« Reply #2 on: September 23, 2008, 10:16:03 am »
It says to use 2 accounts? I use 1 account so it doesn't prompt for a logon. Maybe I'm misunderstanding you.
thatitalian
  • The Revolution Is Coming...
« Reply #3 on: September 23, 2008, 11:24:47 am »
You use two accounts to make adjustments, then when you are done you delete the account.
cmoses
« Reply #4 on: September 23, 2008, 11:33:19 am »
Not at this stage yet, but close.  Can you tell me the link to this in the wiki?
Ginsu Victim
« Reply #5 on: September 23, 2008, 11:42:33 am »
Huh?
G1zm0
« Reply #6 on: September 23, 2008, 01:46:56 pm »
"Here is the process to follow in order to set up your front end as a shell:
You must have at least 2 users with admin privileges
Open the user that will be auto logged in to the account that will be running your front end as a shell. This user should have admin rights.
Set XP to automate the login process."
i take it thats how i adjust the fe from another account?  to get into this do i hold down f8 or something?
« Reply #7 on: September 23, 2008, 01:58:41 pm »
3 finger salute, change user/log off ?
