Author Topic: VMJ Enabled on Startup  (Read 2910 times)
chris-cy
  • Last login:June 17, 2003, 05:48:39 am
« on: June 13, 2003, 02:52:13 am »
Hi all,
My question is as follows: I'm using win 2k, P4, 256MB pc, with all the necessary jukebox key functions wired using I-pac to buttons, and I put VMJ in windows startup.
VMJ is set up to start in full screen mode.
The problem is that when the computer boots and VMJ loads, is not always enabled. I have to click anywere with the mouse to choose the window in order for it to work.
Can someone think of any solution.
Thanx in advance
AlanS17
    • AlanS17
Re:VMJ Enabled on Startup
« Reply #1 on: June 13, 2003, 10:13:09 am »
Off the top of my heaed, it sounds like you have other programs automatically openning at startup as well and stealing the focus. Check your Startup folder for any other programs. Also check any programs that load into your system tray. You shouldn't need them anyways. If anything you'd get a performance improvement (though you're not likely to really notice it).
