Author Topic: Mounting Wico joystick in wooden cp  (Read 2507 times)
halfping
  • Last login:July 18, 2002, 10:50:35 pm
« on: March 11, 2002, 08:38:23 pm »
Any one have any problems installing a 4-way balltop Wico Joystick in a wooden 3/4 inch control panel?  I have seen the ms pacman/galiga joystick and don't see how they could be mounted in a wooden cp.  So I have to go with a Wico.  Any ideas as apprieciated.
Vectoraster
  • Last login:November 19, 2020, 12:55:33 pm
  • You *are* starting to annoy me.
    • The VectoRaster Network
Re: Mounting Wico joystick in wooden cp
« Reply #1 on: March 12, 2002, 04:05:22 am »
I had to use a router.  I know that's the obvious answer but I don't think there are any alternatives.  A small amount of extra effort but it's worth it.
dhenrynj
  • Last login:August 21, 2019, 08:53:12 am
« Reply #2 on: March 12, 2002, 05:02:52 am »
I used 1-4 directional and 2 8-directional wico leaf joysticks in a 3/4 inch oak CP.  I just mounted them to the bottom with carriage bolts.  I used the 4-way from videoconnect.com, so I'm not sure if the shaft is longer than the one you have.  I have no problems with it at all.
