Author Topic: How to setup CPViewer with Mala  (Read 7575 times)
dungbeetle46
  • Last login:June 25, 2016, 07:27:47 pm
« on: September 19, 2008, 12:55:23 am »
Mala & CPViewer
download cpviewer and cpviewer system files
unzip system files and run the setup.bat
unzip cpv2 and read the pdf file in docs folder to setup your layout and to test if you have things working.
once you are satisfied everything is installed correctly, & if you havent already done so, we can now produce your static images,
this can take a while
In windows goto start run
type cmd
press enter
at the command prompt type cd\
enter
then type cd\mame\cpv2
enter
or whatever the path is to your cpv2
now type
cpv2.exe –s
this Will run a batch job that creates snaps off all the Mame games and clones that are currently documented
in the controls.ini file. This process will take approximately 20 minutes to complete.
If you have instruction cards, place these in inside instructions folder inside cpv2 folder
if you have original control panel pics these go in cpanel folder inside cpv2 folder
(THESE MUST HAVE THE SAME NAME AS THE ROM) eg:Ghouls and ghosts = gng.png
This has cpv2 setup, now for Mala
start Mala
right click and go to options
controller
keyboard
external applications and put the following
C:\mame\cpv2\CPV2.exe -r=%rom%
or the path to your cpv2 folder
and under key put the letter you want to use to launch viewer ( I put P so you can launch with Pause Button)
or you can use the cpviewer app under Control Panel Viewer
put a tick in use control panel viwer and decide whether to launch at game start or replace info window in which case it will be
launched with left alt.
I prefer the first option as an external app, then you can use alt for history etc and only use cpviwer when you need it.
make sure you use the -r=%rom%
dont use -r=[name] as stated in cpv2 pdf as this wont work
hope this helps some people
As far as Mala goes I think its the best frontend I have tried so far
Keep up the good work.
Dung
« Last Edit: September 19, 2008, 03:39:33 am by dungbeetle46 »
loadman
  • Moderator
    • MaLa
Re: How to setup CPViewer with Mala
« Reply #1 on: September 19, 2008, 01:29:51 am »
system01
  • Last login:March 04, 2023, 08:06:55 pm
  • System Idle Processes are the Devil's Playthings
« Reply #2 on: September 19, 2008, 03:44:46 pm »
... epic.
I just trashed a test machine getting instantsheller all sorted and was gonna shell my cab tonight.  Now Im gonna have to set this up first. ::)
Thanks! :applaud:
system01
« Reply #3 on: September 19, 2008, 09:18:11 pm »
Does anybody know where to get pretty button pics like the ones on the CPViewer example?  I guess I could render some if I have to...  :'(
retrometro
  • Last login:May 24, 2024, 09:11:44 pm
    • Arcade, mame, retro... and the gp2x.
« Reply #4 on: September 19, 2008, 09:59:31 pm »
I just took a photo of my panel for the picture in the background.  Here's what it looks like before each game.
This is the image that comes up before mala loads... also the desktop wallpaper.
-------- gp2x and retro... play it forever! ------------------------
http://www.youtube.com/view_play_list?p=0EE573E86D5A86E0
system01
« Reply #5 on: September 20, 2008, 01:08:25 am »
I thnk you should change your nick to "retrosexual", just to stick it to all those politicians that try to be hip...  Heh, I said hip.
Anyways, I like your pics.  But Im so crappy at cameras that I knew it would come out like doo-doo if I tried it.  Plus i wanted that "illustrated", "fake" look to match my theme.
So I made these (attached):
I still have to make some one and two player buttons and stuff, and adjust my renders, but so far I think thats what Im going with.
« Last Edit: September 20, 2008, 01:15:16 am by system01 »
retrometro
« Reply #6 on: September 20, 2008, 09:21:36 am »
:-o
the buttons look great.
I made the handle after a buddy of mine here in Texas that lives in the city calls himself MetroTextual.
jimbomame10
  • Last login:June 13, 2014, 12:11:01 am
« Reply #7 on: November 24, 2009, 10:09:12 pm »
Question.  I installed mala and followed the pdf setup for cpviewer.  However, when I try to run a batch job by doing the following:
"In windows goto start run
type cmd
press enter
enter
enter
now type
cpv2.exe –s
in the controls.ini file. This process will take approximately 20 minutes to complete."
I end up getting an error message that reads: "Run-time error '9': Subscript out of range" and no CP displays appear.  Does anyone know how to fix this or what I might have missed?  Thanks!
BamBam
  • Last login:November 03, 2011, 07:18:19 am
  • This is better than Disney Land man!
« Reply #8 on: January 04, 2010, 07:41:40 am »
Oh my.  What nice buttons you have  ;)
Galaga... Was there any other game?
