Well, thanks to the MARP forums, I was able to make a vid!
![Smiley :)](http://newforum.arcadecontrols.com/Smileys/default/smiley.gif)
(see attached .zip below)
I am using MAME32 .119.
The problem was, I was hitting F3 to bypass the maintenance screen, when I should have been hitting F1 instead.
So, when you play the video, once in the game, you type "OK" to bypass the disclaimer. Hit "enter" to bypass the game info and then let the .inp file automatically do the rest to bypass everything.
I know the contest is over, but I managed to score a whopping
625,670!
I only scored
4,240 on the first level (
4,690 is my hi), but it shows the technique that I use to score higher without losing a life.
~ DeLuSioNaL
