Author Topic: Coin Door Wiring help (lighting)  (Read 1574 times)
  • Last login:July 11, 2025, 09:17:44 am
« on: September 04, 2008, 02:18:04 am »
Hello all,
My coin doors are hooked up and working perfectly, except for the lighting.  I have a green wire and a blue wire on the wiring harness for both bulbs.  Which one is ground and which is 12v?
Also, how hard is it to replace the bulb with an LED?
~ DeLuSioNaL
Chase
  • Last login:November 13, 2020, 10:59:55 am
  • Live from Seattle!
    • Home
Re: Coin Door Wiring help (lighting)
« Reply #1 on: September 04, 2008, 02:26:31 am »
Hello all,
~ DeLuSioNaL
Hey Del,
Well on your light, it doesn't matter.  There is no Ground per-se, just a positive side and a negative side.  Just make sure you stick to the same side and color for both lights.
I did the same thing with my lights on my coin door, wired it straight to my PC, and did not have any issue.  More pics below:
http://forum.arcadecontrols.com/index.php?topic=82364.0
On the LED part, while it may look cool, you actually get better effect in my opinion with a standard bulb.
Hope this helps!
- Chase
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #2 on: September 04, 2008, 04:02:35 am »
I'm pretty sure that Happ sells an LED lamp replacement for coin doors, but their site is too big a mess to find it.
Best Kid iPad Apps
  • Last login:August 23, 2025, 09:14:19 pm
« Reply #3 on: September 04, 2008, 12:14:00 pm »
I agree with chase.
The LED lamps run a lot cooler, and they consume a lot less power, and they last for many many years.   BUT  The incandescent bulbs look tons better, and more original.
