Author Topic: Visio templates wanted: Magstick Plus, Happ 3" trackball, standard button  (Read 2895 times)
Diewrecked
  • Last login:June 20, 2012, 07:34:08 am
Hi all,
Subject line says it all. Does anyone have Visio (or whatever) templates for the MagStick Plus and 3" Happ trackball - TOGETHER WITH MOUNTING HOLES, and a standard 29mm button please? Note I am not using a mounting plate for the trackball as it is going into a 2mm steel plate. The templates would need to be 100% accurate because I am going to print the layout template and give it to a car body workshop to drill out for me.
Many TIA you guys
Diewrecked
*bump*
Anyone.... ? Please....? :)
paulscade
  • Last login:December 26, 2022, 09:40:35 pm
    • My Arcade Project - Blastoff!
This will get you your MagStik+.
I make no claim to it's accuracy (it was good enough for me).
... Why is it that you always find it in the last place that you look? ...
kelemvor
  • Last login:May 13, 2012, 09:40:44 am
Assuming the Mag Stik Plus is the same size as the non-plus, you can get the details here:
http://www.ultimarc.com/controldiags.html
