Author Topic: What parts should I order to mount a trackball?  (Read 2067 times)
The cranky hermit
  • Last login:June 03, 2006, 01:35:04 am
  • CP #1: Completed
« on: June 10, 2003, 09:27:36 am »
I am going to get the Wico/Suzo 2 1/4" trackball. It does not come with a mounting plate or bolts. I am going to order what I need from http://www.dameon.net/BBBB/parts.html#tbs
It looks like the mounting plate I need is the Atari TB 2
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
Re:What parts should I order to mount a trackball?
« Reply #1 on: June 10, 2003, 10:10:28 am »
« Last Edit: June 10, 2003, 10:12:04 am by rampy »
mclaught
  • Last login:April 20, 2006, 08:09:11 pm
« Reply #2 on: June 10, 2003, 10:16:49 am »
Are you using 3/4 MDF or a metal CP? If you are using an orignal metal CP, you don't need the  mounting hardware.
The cranky hermit
  • CP #1: Completed
« Reply #3 on: June 10, 2003, 11:04:03 am »
I'll be using 3/4" wood of some kind. Is MDF the most popular type for all-wood CPs? I'm not going to use any plexi or any of that stuff.
rampy
  • *shrug*
« Reply #4 on: June 10, 2003, 12:32:16 pm »
Yes it is... it's very smooth, and great for painting (or laminating, or vinlying)... plywood's ok too, but I'd think you'd only go that route if (a. it was handy  or b. you got cabinet grade plywood and stained it )
that's just a quick outline.
rampy
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #5 on: June 10, 2003, 09:20:40 pm »
Robin
Knowledge is Power
