Author Topic: Y spliter for a PSX2 controller?  (Read 1734 times)
Les
  • Last login:April 07, 2012, 12:05:55 pm
  • "You had me at show your tits."
    • Arcade Legends
« on: June 09, 2003, 04:41:53 pm »
I am kicking off a new project soon and I need some help on integrating console controls into my system.
Is there such a thing as a Y spliter for a PSX2 controller?  I'm not looking for a 4 way hub.  I'm looking for something that splits the same signal from a controller 2 ways.  Not a device that allows 4 people to play on one PSX2 controller slot.
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
Re:Y spliter for a PSX2 controller?
« Reply #1 on: June 09, 2003, 10:06:30 pm »
Nope sorry.  I don't even see a reason why a manufacturer would want to make something like this.  The controller communicates to the host (PS2) over a bi-directional protocol.
« Last Edit: June 09, 2003, 10:14:22 pm by Dave_K. »
Hoe
  • Last login:September 05, 2004, 01:17:09 pm
« Reply #2 on: June 09, 2003, 10:10:39 pm »
Errr, it seems he's asking for one to make one controller, go into two consoles. Most likely so he dosn't need to unplug, then replug it into another console using some form of adaptor for the second. I doubt <i>they</i> make adaptors, but you probly can :P
Dave_K.
    • Arcade Fever
« Reply #3 on: June 09, 2003, 10:12:51 pm »
Thats kinda what I thought too.  There is no way this could work.  The controller would be getting signals from 2 hosts which would surely not work.
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #4 on: June 09, 2003, 11:44:23 pm »
I advise to not do this unless it is switched.
Basically you wire the controls to a switch (like a parallel port switch) then from the switch to the gamepad hacks.
Les
    • Arcade Legends
« Reply #5 on: June 10, 2003, 10:42:59 am »
Basically you are correct.  Here is a synopsis of my design.  I want to have a PSX2 and another console (be it a Dreamcast, XBOX, or other) both connected to my arcade controls and a set of 2 PSX2 gamepads.  This is so I can play my PSX2 and other console on my control panel or traditionally with gamepads.  If possible I only want one set of gamepads controlling both consoles.
armad1ll0
  • Last login:March 28, 2012, 12:24:57 pm
  • The player and the builder!
    • Modeverything
« Reply #6 on: June 10, 2003, 01:39:14 pm »
I could probably make you one for $25 shipped. You want it double on the female end or the male end?
Les
    • Arcade Legends
« Reply #7 on: June 10, 2003, 02:18:59 pm »
I can hack it myself just fine.  I was just wondering if there might be a ready made unit in existance.
