Author Topic: 60 in 1 spinner support ?  (Read 7233 times)
Arm123
  • Last login:March 03, 2025, 11:26:20 am
« on: August 13, 2008, 08:48:02 pm »
Hey guys,
I'm about to convert a showcase cabinet to a 60 in 1 with a trackball.  With Arkanoid being one of my favourites, i have a couple questions.
1. Does the 60 in 1 even have spinner support ? or does this get taken / used by the trackball when installed ?
2. If the spinner works, which product would work best ?
I have heard that the newer 60 in 1's have 2 headers on them for trackball support.  Since my boards have not arrived yet, im wondering if one of these headers can do 'double duty' as a spinner ?
Anyone that can shed some light on this, please do.
miles2912
Re: 60 in 1 spinner support ?
« Reply #1 on: August 13, 2008, 10:16:18 pm »
What is a 60 in 1?  Some commercial product?
Arm123
« Reply #2 on: August 14, 2008, 01:31:40 am »
Hmmm...   sarcasm ?  :o
60 in 1 is a 'newish' jamma pcb board that runs emulation software for classic vertical games.
http://www.jammaboards.com/store/60-in-1-multigame-pcb/prod_212.html
Arm123
« Reply #3 on: August 14, 2008, 02:55:14 am »
I wonder if i could try to hack the track ball header to use the x axis only for the spinner ?
Ill have to wait for my boards to arrive to try it.
Any other suggestions ?
Blanka
« Reply #4 on: August 14, 2008, 03:03:16 am »
Plug-in question:
The 1069 in one uses a Celeron and a hard disk?
Does that one run MAME?
Does it have legal licenses?
Can I thus buy it, and use the HD in my PC?
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #5 on: August 14, 2008, 07:18:21 am »
Plug-in question:
Yes, although I dunno about the exact nature of the processor.
Yes, against license and wishes of MAMEDev.
Nope.
Besides not being licensed, also remember is older version of MAME, etc.
Working: Not Enough
Projects: Too Many
Progress: None
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« Reply #6 on: August 14, 2008, 08:20:24 am »
From what I understand they run a custom chipset and are programmed to output at a certain frequency, so a direct HD swap is unlikely.
Arm123
« Reply #7 on: August 14, 2008, 02:57:27 pm »
anyone ?
CheffoJeffo
« Reply #8 on: August 14, 2008, 03:04:04 pm »
I had a look at my 60-in-1 this morning and it does have two headers (in addition to the connection via the JAMMA harness), but I couldn't find the manual and I don't have a functioning spinner sitting around right now.
Sorry.
Working: Not Enough
Projects: Too Many
Progress: None
Arm123
« Reply #9 on: August 14, 2008, 03:22:42 pm »
No worries my friend...  I guess ill be the gunnie pig   ;D
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #10 on: August 14, 2008, 07:38:39 pm »
If you can hook up a TB, you should be able to hook up a spinner, as both (usually) use the same quadrature signal.  (I'm assuming standard arcade TB's and spinners, not ones with special boards.)
Again, if the hacked mame can see the TB, a spinner should work, but  :dunno
The question is whether a TB & a spinner can be hooked up at the same time (as Cheffo's hint at two headers might mean), or if a switch is needed and both the spinner and TB needs to be wired to the same header.
Let us know how it turns out.
Robin
Knowledge is Power
miles2912
« Reply #11 on: August 14, 2008, 09:16:05 pm »
No man.  Seriously never heard of it... and not sure why you would want one with cheap PC's and MAME?
Arm123
« Reply #12 on: August 15, 2008, 01:41:37 am »
I thought about using MAME...
But i didn't want to go threw the hassle of setting up arcade vga and getting a computer, setting it up, configuring MAME.
This i very easy to setup and enjoy.  My next project, i may get a MAME system up and running.
miles2912
« Reply #13 on: August 15, 2008, 03:53:37 pm »
I hear ya.  Sounds like a great cost effective way to get into the hobby.  Hope all goes well getting the spinner up and working.
