Author Topic: Donkey kong on jamma harness problem  (Read 1182 times)
robstraws
  • Last login:August 29, 2017, 12:28:32 am
« on: August 05, 2008, 09:52:12 pm »
First I'd like to say that I am new here and reading the threads I have found in the last several days have been extremely helpful.  I've been using Markrvp's restoration as a bit of a guide to restore a Donkey Kong machine I acquired several years ago that had been converted into a jamma cabinet.  Since the jamma harness and the pcb were already wired up it seemed as though I only needed the jamma to nintendo adapter so I purchased that and quickly installed it.  When hooking the board up now I only get a mario jumping noise that quietly loops in the background and the screen stays blank.  I thought this could possibly be the monitor but I tested another jamma board that I have and it worked fine.  My guess is that the  pcb isn't giving the appropriate  voltage to the board/monitor but since I am very new to the restoring game I really have no idea how to approach this situation.  Thanks!
« Last Edit: August 05, 2008, 10:04:52 pm by robstraws »
jimkirk
  • Last login:October 27, 2013, 01:24:15 am
  • Ahead warp factor 5 Mr. Sulu.
Re: Donkey kong on jamma harness problem
« Reply #1 on: August 11, 2008, 11:25:09 pm »
You might try the KLOV site if you don't get help here. I find there is alot of very knowledgeable people there and I am sure someone can help you.
I know who Phet is and many of you do not.
