Author Topic: Issue with LED's  (Read 844 times)
TheManuel
  • Last login:April 09, 2025, 10:13:43 pm
  • On and off hobbyist
Issue with LED's
« on: June 08, 2003, 09:02:46 pm »
On games that use the keyboard LED's, if the LED's are flashing, the keyboard inputs become unstable. For instance, when scrolling through the in-game menu, if the LED's are flashing (after inserting coins), for moments, key presses are not registered.
At first I thought it was the I-Pac, but I connected the keyboard directly to the PC and still get the exact same problem.
Is this a MAME, keyboard or motherboard issue?
Thanks.
"The Manuel"
TheManuel
Update: Does not happen with older MAME
« Reply #1 on: June 08, 2003, 09:23:14 pm »
I tried with v0.57 (which I keep for Shinobi) and there are no problems.
Any clues?
"The Manuel"
TheManuel
Solved
« Reply #2 on: June 09, 2003, 01:03:19 pm »
It'a a MAME issue.
MAME changed the way it handles the LED's somewhere between 0.57 and the current version.
The new method, causes this behavior in some motherboards and keyboards.
"The Manuel"
