Author Topic: pc games in MALA  (Read 9259 times)
BORIStheBLADE
  • Last login:February 03, 2012, 10:53:59 pm
pc games in MALA
« on: August 04, 2008, 01:28:38 am »
I have read some old post about running pc games from MALA and to be honest with you they confuse the crap out of me.
Is there a dummies guide to doing this or something?
All I wanna do is run Grid Wars from my cab. :dizzy:
loadman
  • Moderator
  • Last login:January 29, 2026, 07:18:10 pm
    • MaLa
Re: pc games in MALA
« Reply #1 on: August 04, 2008, 07:24:26 am »
Basically you just need to create a folder with shotcuts to your pc games in it.
BORIStheBLADE
« Reply #2 on: August 04, 2008, 08:07:32 am »
ok, I'll give it a try.
BORIStheBLADE
« Reply #3 on: August 05, 2008, 12:45:04 am »
Ok so I got it to work. For simplicity I put a folder on my C drive with a folder of the shortcut. Put in the info you said to use and it works.
The only issue is when I leave Grid Wars I get a error saying failure to execute with a error code 123. If I press esc again it just closes that window and goes back to MALA.
bent98
  • Last login:February 02, 2019, 03:35:00 pm
  • Hyperspin Moderator
« Reply #4 on: August 05, 2008, 09:24:01 pm »
In the execution tab you need to make sure command line only says %rom%
That will fix your error
BORIStheBLADE
« Reply #5 on: August 07, 2008, 12:57:54 am »
Thanks for the tip.
It fixed the error, but now when I quit the game it will sometimes hang and boot the game back up again.
loadman
  • Moderator
    • MaLa
« Reply #6 on: August 07, 2008, 07:07:05 am »
Thanks for the tip.
Does that happen what videos are disabled?
BORIStheBLADE
« Reply #7 on: August 07, 2008, 08:13:08 am »
Do you mean, Does it happen when videos are disabled?
loadman
  • Moderator
    • MaLa
« Reply #8 on: August 08, 2008, 01:08:43 am »
Yes   :banghead:
BORIStheBLADE
« Reply #9 on: August 10, 2008, 12:56:56 am »
ok..... where  should I make sure that videos is disabled? I found it in two different places.
