Author Topic: Does a USB hub create any latency?  (Read 1055 times)
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
« on: August 02, 2008, 11:01:49 pm »
I was thinking of using a USB hub inside of my control panel and plugging my U360's and trackball into it; mainly just to keep things neater.  I was wondering if there was any downside in doing that?  Latency or any other issues to worry about?
paulscade
  • Last login:December 26, 2022, 09:40:35 pm
    • My Arcade Project - Blastoff!
Re: Does a USB hub create any latency?
« Reply #1 on: August 03, 2008, 05:02:29 pm »
The USB specification allows for +5v at 500ma *per port*.  The only way to insure that everything inside the panel gets enough power would be to place a powered hub in the panel... so you would need to run an additional power line to the CP.
(I was considering doing the same thing)
... Why is it that you always find it in the last place that you look? ...
