Author Topic: Cat 5 with quick disconnects  (Read 2203 times)
shmokes
  • Don't tread on me.
    • Jake Moses
« on: August 01, 2008, 04:29:26 pm »
I notice that quite a few people are using cat 5 to do clean wiring jobs in their control panels.  I also notice that quick disconnects are always rated for 16-22 gauge wire.  Do you have any trouble getting a good tight crimp on the 24 gauge wire used in cat 5?  I thought maybe cat 6 or 7 might use a thicker gauge wire, but they don't appear to.
Best Kid iPad Apps
massive88
Re: Cat 5 with quick disconnects
« Reply #1 on: August 01, 2008, 04:35:36 pm »
Im not using cat5 but I just got dome making some terminals with 24 gage wire using quick connects rated for 22 as you say.
Its not really a problem, just make sure you get a good solid crimping.
Ed_McCarron
« Reply #2 on: August 01, 2008, 06:04:10 pm »
In a pinch, fold the cat5 over on itself to double the size, then crimp.
Personally, I don't trust stakons on solid wire.
severdhed
  • Last login:December 18, 2025, 06:44:56 pm
  • RIP Dinosaur Hippo
« Reply #3 on: August 01, 2008, 10:53:41 pm »
we used them on my friend's panel with cat 5 and it worked jsut fine. we just folded the ends of the wires in half and crimped them very tight with long handled channel lock pliers.  no problems at all
« Reply #4 on: August 02, 2008, 12:30:29 am »
They look a little funky since the wire is so skinny compared to the crimp.  But mine hold just fine.  My entire panel has cat 5.
TIP:
I got mine for dirt cheap here:  http://www.cablewholesale.com/catalog/cat5enetworkcables.htm
I was able to color coordinate my cables which made wiring easier.  They have tons of colors to choose from.  I just got at few 7ft booted cat5e cables (I cut off the ends) in several colors.  They go for $1.60 each which is dirt cheap!
~ DeLuSioNaL
