Author Topic: Q: GGG TT2 and Electric Ice Trackball  (Read 1450 times)
paulscade
  • Last login:December 26, 2022, 09:40:35 pm
    • My Arcade Project - Blastoff!
« on: July 13, 2008, 12:42:34 pm »
I want to buy one of each for the cabinet that I'm building.
The TT2 can be purchased as a master (w/interface) or slave.
Can the TT2 be purchased as a slave and hooked up the to Electric Ice Trackball?  Does the necessary cable come with the TT2?  ???
The advantage would be that I would have only one USB cable [leading to the PC] supporting both devices.
Is there a disadvantage?
Hey GGG... is your website e-mail working?... I've asked this question directly and I didn't get a response.
... Why is it that you always find it in the last place that you look? ...
RandyT
  • Last login:March 17, 2026, 03:35:03 pm
    • GroovyGameGear.com
Re: Q: GGG TT2 and Electric Ice Trackball
« Reply #1 on: July 13, 2008, 01:33:55 pm »
The trackball can be attached to the TT2 interface, but not the other way around.  In doing so, you would be limiting the TT2 to the Z-Axis, which, because of the way the OS handles the Z data, is more sensitive than the X or Y without either patching MAME or finding a release that fixes this.
If you are interested in doing this, I can supply a special version of the trackball that will allow a TT2 Slave to attach to the Z axis on the trackball interface.  But you would need to specify this in the comments section at the time of checkout.
RandyT
paulscade
« Reply #2 on: July 13, 2008, 05:27:31 pm »
Tkx! RandyT
