Author Topic: Has anybody designed a control panel so you can fit chairs under it?  (Read 1688 times)
sofakng
  • Last login:February 18, 2021, 04:19:21 pm
I've had my stand-up (eg. traditional) arcade cabinet for a while now but I'm lazy and don't like standing for long periods of time so I have two tall chairs (like barstools but with a back), but it's uncomfortable to sit on them because my knees hit the cabinet and I can't get close enough to the control panel.
Does anybody else have this problem or does everybody just stand the entire time when playing? :)
I'm thinking about moving my control panel box closer to the front of the cabinet but it's not going to look that great because there will now be a huge gap between the screen and the control panel box, etc.
Ginsu Victim
  • Comanche, OK -- USA
Re: Has anybody designed a control panel so you can fit chairs under it?
« Reply #1 on: June 20, 2008, 10:20:16 am »
You can either build a new panel and make it come out further, or you can look into buying a candy cab.
sofakng
« Reply #2 on: June 20, 2008, 10:59:22 am »
Thanks for the help.
I have a couple of ideas about what I can do but I was wondering what everybody elses opinions are and if they have the same problem, etc.
Ginsu Victim
« Reply #3 on: June 20, 2008, 11:05:15 am »
I'm in the same boat as you. I have a tall stool with a back and my knees bump the cab as well. Still more comfy than standing for long periods of time.
mhermann
  • Last login:October 04, 2019, 07:10:08 pm
  • We ain't found.........
« Reply #4 on: June 21, 2008, 12:26:45 am »
You truly are the sofa king!!
« Reply #5 on: June 21, 2008, 10:41:18 am »
My barstools are adjustable so I can get my legs under the CP if I want. Bigger problem for me is reaching the coin slot!
Ginsu Victim
« Reply #6 on: June 21, 2008, 08:28:28 pm »
My control panel doesn't stick out at all, so I can't get under it in any way. Luckily the reach isn't too bad, but I've been working on a CP redesign.
Ummon
  • Trade Count: (+13)
« Reply #7 on: June 22, 2008, 10:51:30 pm »
You could redesign it. Or you could put a panel over the space. Or you could make it a cubby for drinks and stuff.
Yo. Chocolate.
Stephen Hawking
Dreamwriter
  • Last login:August 28, 2010, 04:33:09 pm
  • Sleep is for the weak!
    • Games of Yore
« Reply #8 on: June 23, 2008, 02:44:48 am »
My local arcade has a dual "Lindburgh" cabinet designed for sitting down with your legs underneath the CP.  Works well, but if you *wanted* to stand and use it, you couldn't.
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« Reply #9 on: June 23, 2008, 05:04:22 pm »
I designed most of the Turnarcades line-up with the standing/sitting versatility in mind. The 'Master' was modelled on the generic 2-player cabinets that graced so many arcades I went to growing up. Having the shallower control panel than the amerian-styled machines allows for a sturdy and aesthetically pleasing overhang that means you can stand closer to the machine without stubbing your toes, or sit on a bar-stool with your knees under the panel, meaning you arch your back less. Even the 'Mini' cabinet was designed with the cp height set so you could sit in a regular chair to play it.
valiant
  • Last login:March 05, 2022, 02:49:23 pm
  • One of three lions...
« Reply #10 on: June 24, 2008, 06:08:24 am »
Cut a few inches off the legs of your bar stool?
