Author Topic: Using original cab's speakers for a MAME conversion  (Read 1369 times)
vidmouse
  • Oop! Ack! Thppphbt!
    • Vidmouse's Arcade
« on: June 01, 2008, 07:02:33 pm »
Working on two  MAME conversions right now, both cabs have their
original speakrs.  My first cab was a scratch-build, and I used some
PC speakers so it was easy to hook up sound.  Not sure how to do
it if I try to use the speakers that are already in the cab... do you have
run them to some kind of AMP and then to the PC?
RayB
  • I'm not wearing pants! HA!
  • Last login:July 10, 2025, 01:33:58 am
  • There's my post
    • RayB.com
Re: Using original cab's speakers for a MAME conversion
« Reply #1 on: June 01, 2008, 07:35:13 pm »
Yes, unless you have a sound card capable of amping up the output. Sometimes setting the soundcard to "headphones" makes it pump out higher volume.
If that doesn't work, use a cheap set of PC speakers, remove just the speakers and wire up the existing cabinet speakers instead.
NO MORE!!
Ummon
  • Trade Count: (+13)
« Reply #2 on: June 02, 2008, 03:16:16 am »
I think there's stuff in the wiki on this. Plus, isn't some of Oscar's old stuff (like this) archived there?
Yo. Chocolate.
Stephen Hawking
Ninja-chicken
  • Last login:September 27, 2009, 05:06:08 pm
« Reply #3 on: June 02, 2008, 07:09:55 am »
I used the original speakers in my cabinet. I just taped the speaker wire to an old phono to headphone converter (see link below). Then I plugged that directly into my sound card (on board actually) and it works a treat. It's very loud, but not all sound cards are powered so yours might not work so well...
http://cgi.ebay.co.uk/Philips-Headphone-to-Hifi-adapter-3-5mm-plug-to-2-phono_W0QQitemZ280231700312QQihZ018QQcategoryZ112531QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
