Author Topic: NEW LCD Topgun driver  (Read 3131 times)
deano728
  • Last login:November 04, 2013, 10:59:53 am
« on: May 28, 2008, 07:54:58 pm »
I have resumed trying to get my LCD Topguns to work (still to no avail).
In my attempts to get it to work, I noticed that there is a brand new driver just posted on May 9th, 2008 and promises to support MAME and get the gun working perfectly.
Here is the link: http://www.hkems.com/m_main.htm
My problem is that I cannot figure out how to uninstall Smog's drivers.  It seems that no matter what I do, XP tries to install them when I attach my lightgun and it won't allow me to target the driver...  Any advice?
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
Re: NEW LCD Topgun driver
« Reply #1 on: May 28, 2008, 09:26:40 pm »
Will have to try this and hopefully get the topguns working ready for my new arcade machine. Spent too long building cabs for customers so gonna build a new grand-daddy machine for myself!
deano728
« Reply #2 on: May 30, 2008, 08:10:06 pm »
I had tons of problems with smogs driver on my cab.  I just uninstalled and installed the new LCD topgun driver and it works like a dream...   I am not sure if these drivers work with 2 guns or not, but I will let you know when I try it out.  If you are having problems getting your guns to work, try these out, they worked for me.
If anyone has tried this driver with 2 guns, please let me know if it works.  It could save me some time!
aljupy
  • Last login:October 23, 2011, 07:30:06 pm
« Reply #3 on: May 31, 2008, 04:26:46 am »
It works
mhermann
  • Last login:October 04, 2019, 07:10:08 pm
  • We ain't found.........
« Reply #4 on: May 31, 2008, 06:42:57 pm »
I would love for this to work as I am having a hell of a time trying to write a driver for the wii motes. Although I am dedicated to getting that done, part of me hopes these work so I can move on to something else. (Thats my frustration talking.)
Organic Jerk
  • Last login:May 09, 2013, 12:39:09 am
  • I'm per pixel lit.
    • OmeshPersaud.com
« Reply #5 on: June 01, 2008, 12:34:41 am »
It works
Care to elaborate?  Two guns work perfectly out of the box with little calibration? What did you have to do?
Progress Rate:  Moderate      ||      Threads:  Cabinet  |  Art  |  MaLa Layout
XBL: OrganicJerk  |  PSN: OrganicJerk
mhermann
« Reply #6 on: June 02, 2008, 09:20:36 am »
Yes, please elaborate. Can anyone else provide more details?
aljupy
« Reply #7 on: June 03, 2008, 12:27:51 am »
What do you want to more elaborate?
1)We said hundred times it is MAME and multiple LCD TOP GUNS compatible
2)We said that if you have a TOP GUN it is the official driver, so it is the best for Top Gun (It just need some options that Smog´s had)
It is said here, on the expand 47 page thread  ;D ;D ;D http://forum.arcadecontrols.com/index.php?topic=48982.1840
Come on....what are you waiting for install?  ;D ;D ;D
Organic Jerk
    • OmeshPersaud.com
« Reply #8 on: June 03, 2008, 01:29:27 am »
Yeah... Awesome, dude....  ::) that thread has been here a "hundred" years longer than the new drivers, which came out only last month.
Many of us were using Smong's drivers BECAUSE we could not get things working properly, and still had some issues to work out anyway.
The point of the question is to ask what the specific differences are to those who have had experience with the driver.  Especially because there is no documentation, and getting rid of old drivers and installing new ones for unofficial hardware can often be a PAIN.
;D ;D ;D  ::)
« Last Edit: June 03, 2008, 01:31:20 am by Organic Jerk »
aljupy
« Reply #9 on: June 03, 2008, 04:03:34 am »
Yup, but I think it is pretty well explained in page 47. Around from the middle to the bottom.
Even with some Snapshot  ;)
-Regards
Organic Jerk
    • OmeshPersaud.com
« Reply #10 on: June 03, 2008, 08:08:34 pm »
-Regards
Umm... That works..   :angel:             :soapbox: ::)
I didn't think people were still updating that immense thread...
deano728
« Reply #11 on: June 04, 2008, 12:09:23 am »
Dumb question, but I thought I'd ask since I'm not that smart.  I had been using mame32ui and just switched to using mame.  My lightguns work in mame32ui, but not when I try using it through mame.  What settings do I need to put into mame.ini in order to make this work with mame?
headkaze
  • 0x2b|~0x2b?
« Reply #12 on: June 04, 2008, 01:14:05 am »
Try the following
Code: [Select]
# CORE INPUT OPTIONS
lightgun        1
# CORE INPUT AUTOMATIC ENABLE OPTIONS
lightgun_device           lightgun
deano728
« Reply #13 on: June 04, 2008, 11:29:49 am »
Thanks Headkaze!  I will try it out when I get home from work.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #14 on: June 04, 2008, 04:22:20 pm »
If that doesn't do the trick is to open the "old" mameUI32 ini folder, and look at the settings in the mame.ini file (if you still have it).  Compare that to the "new" mame.ini in the mame folder.  Look in the input sections noted in headkaze's post.
But do as headkaze said first; those are the most probable things that are different.
Robin
Knowledge is Power
