Author Topic: Grid Wars 2: u360 Controller Patch - v5.04.12  (Read 36496 times)
nukedawg
  • Last login:May 08, 2021, 10:25:12 am
Re: Grid Wars 2: Arcade Friendly Patch (Dual U360)
« Reply #40 on: May 25, 2008, 06:30:51 am »
DONE.
That did the trick! Thanks for the speedy update! I am already beating my old hi scores now :)
wwwombat
  • Last login:February 24, 2011, 08:13:59 pm
Re: Grid Wars 2: Arcade Friendly Patch (Dual U360) (Mouse+Joy hybrid)
« Reply #41 on: May 29, 2008, 10:00:04 pm »
I've kept an eye on Grid Wars 2 for my cabinet and now that it has dual U360 support I thought it was time to fire it up again.
However the old issue I have with the game still exhibits itself... I am running this on an Intel Dual Core 3.00GHz with an 8600GT grpahics card on a 1920x1200 LCD monitor (@ 60 Hz).
I get insane flickering of the screen no matter what internal resolution I set it to (and when I do do this the navigation through the configuration becomes insanely slow).
From piecemeal evidence I've seen around the web (and there's not much about) there was some suggestion about turning anisotropic filtering off but this doesn't seem to have (much of an) effect.
I know the game (I have it for Wii and NDS) and the cabinet does play similar items like Echoes (although I'd like a U360 option for this as well) and Geometry Wars Evolved as well as advanced PC games like Call Of Duty 4 and Unreal Tournament 3 without drama  but I cannot get this game to be playable without this strobe effect.
Any thoughts?
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #42 on: May 30, 2008, 12:55:42 am »
The game itself is a Pure OpenGL 2d application and is not multiply threaded and is running in 32bit color depth and 60hz.
There exists a DirectX version in BlitzMax driver, but most case OpenGL is noticy faster, a least here (even I use a 8600 graphicscard my self). But your driver might not like that driver.
Otherwice it look like it a OpenGL graphicsdriver issue, since it play perfect here with less specs.  Do you have newest version and also newest version of Direct9x (there exits many of them)?
But I see I can add some graphics options to set the driver and as well depth in the next version, since DirectX can been faster for some.
Katana Man
  • Last login:September 22, 2024, 12:10:44 pm
« Reply #43 on: May 30, 2008, 02:32:06 pm »
Is this the demo or full version of Grid Wars 2?   If it's the demo, does your patch work on the full version?
EDIT:  Nevermind, I see that it's freeware.  Awesome!
« Last Edit: May 30, 2008, 02:40:59 pm by Katana Man »
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #44 on: May 30, 2008, 07:26:00 pm »
Yep, its freeware and is discounted by the original author (Mark Incitti), due to a threat from Microsoft. Mark Incitti have release a similar game (AtomHex), but have very different gameplay than this game, but have similar graphic style.
wwwombat
« Reply #45 on: June 02, 2008, 08:37:12 pm »
There's the clue to my flickering etc. problems. I had my desktop set to 16-bit whilst I was fine-tuning some Visual Pinball problems. Set my desktop back to 32-bit color depth and the strobing effect is now gone when I start up Grid Wars 2. Now I just need to set the left joystick to move and the right to fire and I'll be good to go.
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #46 on: February 02, 2009, 02:49:19 am »
I hope people still like this game and there is comply of month since I updated the unofficiel patch. So I have a little update today.
Space Fractal
  • Space Fractal
    • Space Fractal
Re: Grid Wars 2: u360 Controller Patch - v5.04.09 Sound Fixed
« Reply #47 on: February 07, 2009, 08:09:32 am »
Finally fixed the sound issue in Vista and adding costume mp3 track support.
nuka1195
  • Last login:April 18, 2020, 08:47:25 pm
« Reply #48 on: February 07, 2009, 09:02:45 am »
thank you
ids
  • Fighter Captured
« Reply #49 on: March 19, 2009, 08:25:22 pm »
Any hope of supporting U360's if they're not among the first 4 joysticks?
Any hope of being able to configure which stick is move and which is shoot?
Sorry, don't mean to sound like I'm complaining - awesome work, and greatly appreciated!
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #50 on: March 20, 2009, 06:10:00 pm »
Im looking on that.....
[EDIT]
I hope blitzmax can handle it, so test the new exe, since I can test it by my self. But I have just adde the possible to choice from port 0 to 7 now with user selectable of the fire joystick.
« Last Edit: March 20, 2009, 07:01:05 pm by Space Fractal »
nickynooch
  • Last login:August 29, 2020, 02:54:00 am
Re: Grid Wars 2: u360 Controller Patch - v5.04.10
« Reply #51 on: July 18, 2009, 11:47:16 pm »
I've got 2 U360's and I cant figure out the config for the life of me.  In the joystick settings do I use config 0,1,2, or 3?
I keep trying different stuff and it seems that in 0 and 1 in recognizes the first joystick, in 2 in recognizes the second for config.  I just cant get it to do both at the same time!
Any ideas?  Maybe I am just not doing something right.
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #52 on: July 19, 2009, 05:17:55 am »
not sure what you mean?
You should use "Dual Analaog (2 ports)" as type controller and select port 0 for movement joystick (left click) and 1 for fire joystik (right click) or what the ports the joystick may use.
« Last Edit: July 19, 2009, 05:30:01 am by Space Fractal »
nickynooch
« Reply #53 on: July 24, 2009, 12:26:06 pm »
I guess it is just having an odd time with setup.  Somehow I got both working once, but the wrong way (player one shot and player 2 moved).  I guess something must be weird with my setup or something, but I have 2 U360s as my only 2 joysticks, so it should work, but oh well.
Both joysticks look good in the setup.  I'm going off of memory but in the setup contoller 0 shows up as the left joystick and controller 1 shows up as the right joystick.  But when I start the game it moves and shoots at the same time with the left joystick.  Right was pretty much worthless.  Also it starts with it shooting up and to the right automatically.  Dunno what that is about.
I'll test more and play with it.  After spending a couple hours though, I think I may give up.
Thanks for the help though!  Hope this doesn't sound like I'm griping, because I totally am not.  Just getting frustrated trying to fix it.
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #54 on: July 24, 2009, 01:40:38 pm »
I think I known what it happens. You have a swapped setup? Also fire on port 0 and movement in port 1?
If yes, there is a bug in the loading code, which I got fixed very soon (please know I did NOT created this game, only the controller patch).
Sorry for the confuction and the bug should now been fixed in 5.04.11.
Hopefully it works in the new version....
« Last Edit: July 24, 2009, 02:04:48 pm by Space Fractal »
headkaze
  • 0x2b|~0x2b?
Re: Grid Wars 2: u360 Controller Patch - v5.04.11
« Reply #55 on: July 25, 2009, 05:05:45 am »
You might want to check out JoyID's from here. It should allow you to make sure you have the joysticks in the correct order when you run a game.
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #56 on: July 25, 2009, 03:34:08 pm »
Headkaze, its was a bug.
If fire joystick was set to port 0, it would auto change to port 1 after the config was loaded, which it should not (why I did do that?). It even didn't checked the movement joystick might have allready set to port 1, so then same joystick controlled fire and movement. Its should never been happens and have been checked that in the config in code.
Yes normal it should not been played in swapped order, but when I also patched it with a selectable ports for each joystick, it should not suddenly change.
I have and should fixed that one in version 5.04.11 (just one line code did that).
« Last Edit: July 25, 2009, 03:46:19 pm by Space Fractal »
nickynooch
« Reply #57 on: July 26, 2009, 03:37:50 pm »
Well it is still shooting in the upper right corner for some reason, and moving VERY slowly in the upper right corner.  It doesn't seem to matter where I map the "center" in the box on the config, but not that big a deal, just a minor annoyance.
However, something I really need help on.  The space bar is the only way I can start the game.  Is there another way to start it?  I can't find a way to map the "start" button to my joystick.
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #58 on: July 26, 2009, 05:47:26 pm »
1. For starting game, by now I think XPadder is your friend. Its a cool utility to remap joystick buttons to keyboard. By now these are hardcoded to the bomb button on keyboard (Space as default) and 1 key. In next version joy bomb button would also been used to start the game.
2. You can adjust the center under the config by pressing on the joystick sqaure and hold down SHIFT button and adjust the deadzone a little bit by using arrow keys (to around 0.1 or 0.2).
This should prevent stopping the ship moving when centered.
« Last Edit: July 26, 2009, 05:59:44 pm by Space Fractal »
Space Fractal
  • Space Fractal
    • Space Fractal
Re: Grid Wars 2: u360 Controller Patch - v5.04.12
« Reply #59 on: July 27, 2009, 02:03:54 am »
bomb key should now been fixed in v5.04.12 so you can start the game using that and works on pots fire and movement joystick.
For more precision what I meant to fix the deadzone issue to prevent the ship move slowling can been done here:
nickynooch
« Reply #60 on: August 03, 2009, 03:22:10 pm »
Thanks man!  I gotta try out the latest.  Even though I haven't gotten it working 100% for me yet (it may though when I test it out tonight) I have to commend you on the work you are doing to make this cab friendly.
nickynooch
« Reply #61 on: August 04, 2009, 11:40:35 am »
Tried the update and now the "y" axis is showing up yellow-orangish on the config when I try to config my 2nd joystick.  It seems that with the 2nd joystick now it only recognizes up and down.  I tried to reconfigure, but no luck.  The previous version worked great except for the centering (which the shift thing may work) and the no-start button thing.  Any ideas in the config what I am doing wrong?
ugglight
  • Last login:February 26, 2011, 03:50:09 am
« Reply #62 on: February 25, 2011, 09:23:49 pm »
i like game BlitzMax,thanks the patch :laugh:
PsychoMikey
« Reply #63 on: March 03, 2011, 05:54:40 am »
This game is so AWESOME! It's running super smooth and it's a blast to play.
I use the trackball for ship movement and my left joystick for shooting. Going of the stick for the bomb button is not ideal but it makes for intresting gameplay. Since everybody has the same handicap it's ok for high-score playing.
Only thing that would make it even more awesome is to add is a 2 player mode and coin insertion to make it more arcade. But since the core development is not continued (as far as i know) that's just wishfull thinking.
Very nice job on the update though!
« Reply #64 on: March 03, 2011, 07:53:41 am »
+1
I still go to GridWars 2 (Space fractal's patch) about once every 2 to 3 days. It's the very definition of "in your face blastem arcade" games.
I'd love to see a 2 player version as well, but that's pretty high expectations.
I wish I could run it full screen 1920x1200 but I've never been able to get that to work correctly.
Still, great game!
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #65 on: March 03, 2011, 12:18:12 pm »
I cannot test why it fail on that resoulution. Its support 1080p fine, which is the max resoulution I can use. Howover of course I dont plan to expand this game other to fix some controls and being arcadecab.
Howover the game might crash when change resoulution, but should keep it when you restart the game.
« Reply #66 on: March 03, 2011, 10:00:24 pm »
Yeah, I noticed the patched ver tends to crash out when you change some settings. Hasn't been a big deal, but I did wonder about that.
« Reply #67 on: May 10, 2011, 12:27:02 am »
Just an update on this
First, finally got gridwars running fullscreen 1920x1280. Awesome, though it does change the nature of the game a bit (lots more space for running around).
Also picked up AtomHex, also by Marc Inciniti.
Very cool game. i wish it had a soundtrack instead of just the sound effects, but, the effects are very well down, graphics are spot on and the game play is very challenging, lots more elements to it than gridwars.
Haven't played with them on the cab yet, but neither seem particularly suited to cabinet play. Not from a controls perspective, but they just don't seem like cab type games.
